bad vibrations
marty b
bad vibrations
Post by marty b »
can anyone give me some ideas as to why at about four and half 1000 revs an upwards im getting bad vibrations through the foot pegs/frame ive got recently new tyres so wheels balanced ,mot was last month so i dont think anythings lose i know my carbs need a clean and probably want balancing , could this be my problem or is it something more sinister , its only started this week an i dont want to ride it if its going to be somthing major..............ideas please :eh: :?: :?:
Re: bad vibrations
It certainly won't help. If it's only at 4500 rpm and not throughout the rev range I wouldn't worry too much about it. I expect the bike will be safe to ride. Have you got the original exhaust on the bike? You could check to see if the exhaust mountings on the pegs are done up tight.
marty b
Re: bad vibrations
Post by marty b »
cheers carl il av a gander at them , though to be honest i gave them a little shake today an they seemed ok , will av proper look tomorrow :wink:
Re: bad vibrations
While your at it, check the chain for any tight spots and is adjusted properly as this has been known to cause vibrations as well. :thumbup:
Steve97
Re: bad vibrations
Post by Steve97 »
Mine used to vibrate alot i put it down to the v twin thing of they all do it, not so, noticed a slight amount of wear on rear offside wheel bearing, so replaced em all, and the chain and sprockets coz they were on their way out, and balanced the carbs, also if you have cans on with link pipes that have brackets that attatch to the foot rest plate, this dosent help I cut them off, vibration is still there but a hell of alot less
StormingHonda
Re: bad vibrations
Post by StormingHonda »
cybercarl wrote:While your at it, check the chain for any tight spots and is adjusted properly as this has been known to cause vibrations as well. :thumbup:
He will only get the vibrations and a slight noise from the chain side, I've had two bikes now where previous owners have tightend the chain right up and pass the bike onto me, the Triumph needed new chains and sprokets because the previous owners efforts of chain adjustment, I swear some people do them on paddock stands.
Vibrations on V twins are normal, if he sat on my Harley he wouldnt like the vibrations on that, but the ladies do :lol:
