Broken Down, Bugger!!!!!
Re: Broken Down, Bugger!!!!!
Yeh the Halfrauds one will do the job I ended up doing the same http://www.halfords.com/webapp/wcs/stor ... yId_255216
A magnetic pick up tool is handy as well, for lifting plugs out amongst other things.
I doubt you caused any damage in 10 miles. A bit of extra stress and strain on the one doing the work. It would run rough on one cylinder though, no surprise there.
Griff, my bike is sat in the workshop here at home, I realise its a bit of a treck but you can come over and we have a few parts to swap over to check it works if thats any help??
Yes, it's the bad cylinder kicking in briefly, and no, you haven't done any damage.
Halfords visit today to buy spark plug removal device!
My simple 'plug diagnosis' made: at first, rear cylinder not firing as when front HT lead removed, engine doesn't run. So plugs swapped around. Bike runs. Front HT lead removed again, engine doesn't run.
So. I guess plugs aren't the issue though ordered 2 new ones as spares! What next and how? HT leads faulty? Coil? And is it easy enough to continue diagnosis myself? Any tips? As I've got 80 flat packed medium sized packing boxes in my garage (anybody want them before Mon!?) I think I'll have to wait for more garage space!
I got the biggest back fire earlier on. Bloody hell!!
Hope workshop day went well? Wish I could have been there!
Griff.
Griff.
KriegerCCTs,HEL oil lines,+4 advancer,+1/-1 sprockets,6mm spacer,CBR1k Sidestand,'07 R1 R/R,HyperPro springs F&R,Pipe Werx SL Carbons,Oxford sports hot grips,Mori style belly
Immediate plans:Clean it!
Do the same with the coils. Swap them around.
Carl, will do, now wheres that Haynes manual.....!!!
Yuk.Haynes manual
Nope, wasn't me that wanted them.Griff1977 wrote: Any tips? As I've got 80 flat packed medium sized packing boxes in my garage (anybody want them before Mon!?)
I've no room in my garage either.
Hahaha. Nice one Tony! Boxes gone now, got the garage back!
Right. It was the rear coil!!!
Gave bike to RM Motorcycles of Beverley this am and the brief was - you only have it for an hour!!£££. So I get a call saying its the rear coil and they are happy me ordering off eBay to be sent to them. Done. £15 delivered. Pick up Fri.
They said its running fine with coil swapped, just on rear cylinder now so def the coil.
Just want to get it back & give it a good clean- it needs it!!
Strange for the vacuum pipe to come loose then the coil go?! Is it?
I might get it dyno'd for interest. Any good places in Yorkshireshire that anybody's knows of? Or am happy to travel.
Anyway, a happier Griff (though I'll be happiest if I'm blasting around on it this Fri eve!).
Griff. Oh Carl, ta for that. Ace.
You could have checked that yourself and saved the money......ah, well, nearly sorted now.
Good news buddy,I used Jordans in Leeds to get mine dyno'd
Good news mate, that must be a relief. Could just be a coincidence the coil going at the same time. Electrics are a funny thing and can just go at any time when you don't need them to.
At least the sun will be shining for your next ride out.
DRS 1101 Hessle Road Hull have a Dyno, or John Warrington Motorcycles 78 Castlegate Malton not too far from you
redvtr
