just played the avoid the man hole cover swerve left swerve right game
We'll have to get you a courier vest. You will be filtering through the traffic like a pro then. :lol:
yesterday was mental busy for me, carl, and my mate chris...aka the mechanic
befrore they arrived i striped the bodywork of the bikes ready to complete a long list of jobs
heres what we achieved
re-routed and repaired the wiring loom
semi repaired the o/s rearset
fitted new chain
fitten new kill switch
fitted new undertray and rear led lights...(bastid of a job)
had another tinker with the carbs
set the tps to bang on 500
fitted a different bottom to the airbox
fitted a new 100% brighter headlight bulb
fitted a freshly painted front subframe
i also got the chance to tighten all the fixings on the fairing and sort out the indicators
the only things we couldn't do was the 19ltr tank conversion, this was my fault tho because i needed to buy a certain part and i couldn't find one at short notice, still i hope to sort it out next week.
we also run out of time and didn't get a chance to repair the minor damage to the exhaust.
carl and chris were fantastic, i even got to see carls fish impressions :lol:
i'm over the moon because i have a fuel warning light for the first time :D
and fingers crossed no more blown fuse's :roll:
in fact i'm just about to finish bolting the screen and fairing lowers back on....
thanks again lads for all your help... :thumbup:
bigspanishmarty wrote:yesterday was mental busy for me, carl, and my mate chris...aka the mechanic
fitted new chain
And swept up the gravel at the end of your road?
fitted new chain
Nah Tony he got someone else to do that as well....... :lol:
cliveyandrews
Post by cliveyandrews »
Dropped mine off with Daz at "The Bike Shop" in Tamworth for an MOT - asked him to sling on my lightened flywheel while he has it, we were unable to get to Mids workshop day to do it, I'll be commuting in the Jaaaaaag this week anyway. Need to look at Pauline's, only firing on one cylinder, the other with occasional bangs from the other. Suspect fuel related as it hasn't had a run over 5 miles since the CCTs were done. I'll check for pinched hoses and vacuum pipe routings etc. strange - it took about 40-50 miles before it manifested, didn't think the carb bowls were that big - maybe a partial fuel feed? /;-?
Sent from my iPhone using Tapatalk and my fat thumbs...
Audi, Vide, Tace
seb421
Post by seb421 »
Had a bit of a mad order day on ebay
Oil Sandwich Plate Universal Fit gauge sender RED > http://www.ebay.co.uk/itm/160490520789? ... 1439.l2649
Water Temp Gauge Radiator Hose Sensor Adaptor 28mm GOLD > http://www.ebay.co.uk/itm/180899985324? ... 1439.l2649
Gauges have the required sensor probes for the above fittings included
Micro Digital Water Temperature Gauge ,Autogauge, 37mm > http://www.ebay.co.uk/itm/160640236635? ... 1439.l2649
Micro Digital Voltmeter ,Autogauge,37mm dia,Ultralight > http://www.ebay.co.uk/itm/180635159056? ... 1439.l2649
Micro Digital Oil Temperature Gauge ,Autogauge, 37mm > http://www.ebay.co.uk/itm/180635163778? ... 1439.l2649
Breathers for the Air box mod's work
Mini Oil Breather Air Filter - Fuel Universal Small Chrom... x 3 in 15mm two blue one red > http://www.ebay.co.uk/itm/290677442170? ... 1439.l2649
Vacuum / breather hoses > two of the hoses are 1mm ID oversize but hope this wont cause a problem at the fittings?
Ordered various lengths of the 3 types
http://www.ebay.co.uk/itm/260859756315? ... 1439.l2649
http://www.ebay.co.uk/itm/261067328695? ... 1439.l2649
http://www.ebay.co.uk/itm/250426303220? ... 1439.l2649
Got a 6mm T peice to replace the plastic 5mm one in the rear vac pipe for a snugger tighter fit
6mm 1/4" BRASS BARBED T - Piece 3 way Fuel Hose Joiner > http://www.ebay.co.uk/itm/250533857658? ... 1439.l2649
Fuel Petrol Filter Honda XL1000 1999-2004 Varadero x 2 > http://www.ebay.co.uk/itm/280550991247? ... 1439.l2649
These Quick release couplers might be to small at 8mm as the hose is 10mm ID but worth a punt?
Quick release Fuel Line Coupler 8mm Race Track Bike x 2 > http://www.ebay.co.uk/itm/200791373967? ... 1439.l2649
Carb jets
SLOW / PILOT JET for PWK KEIHIN OKO CVK # 50 x 2 > http://www.ebay.co.uk/itm/260988938816? ... 1439.l2649
SLOW / PILOT JET for PWK KEIHIN OKO CVK # 52 x 2 > http://www.ebay.co.uk/itm/261043144485? ... 1439.l2649
Bloody hell mate, shopping like a woman there. :lol: :lol:
seb421
Post by seb421 »
cybercarl wrote:Bloody hell mate, shopping like a woman there. :lol: :lol:
[youtube][/youtube]
haha
Them pilot jets won't fit as they are not for a cv carb :-) I think
seb421
Post by seb421 »
lloydiecbr wrote:Them pilot jets won't fit as they are not for a cv carb :-) I think
Bugger they looked right size and look the same as the pilots that are in the constant velocity carbs?
Sent from the Bat Cave via Cup and String
I don't know I think they may be OK. I know it says PWK but then have a look at the applications list here
http://www.ebay.co.uk/itm/130484446234? ... 1423.l2649 as long as they are for the series 21. I don't think you will be needing the 52 pilots though.
I was looking at the yesterday .
In the listing is say what carbs they fit
And it has no mention of the cv :-(
But as you will have them in a few days let me know if they do fit :-) as I need some 50s
seb421
Post by seb421 »
to confirm just measured them against a pilot from a storm CV carb and its exact same measurements and holes are in same place also :biggrin
Well done Seb
No but it is a series 21 jet which is what we need for our carbs. N424-21
benny hedges
Post by benny hedges »
the ones i got were off a crf450 - same part number. i found the 50s worked best for me but had to tweak the mixture screw to get em spot on.
ive got the adjusting tool in the garage if u need to use it seb.
