Could someone tell me the internal hose diameter of the small coolant hose that sits in the V? I have a small leak coming from this hose, I have changed the clips but still leaking so can only assume the hose is kapput!
Thanks
Small coolant hose diameter?
Re: Small coolant hose diameter?
I wonder if it's the same size as the carb breather hose http://www.vtr1000.org/phpBB3/viewtopic ... 98#p215529 yoy could try it and see. It can be added to the list once the size has been confirmed.
Just so others know which one you talking about
From memory it's between 15 and 20mm ID, so get a length of 20mm ID and a couple of new hose clips and make one.
It's a straight length of hose, so nothing fancy needed.
They often leak, and it's a bugger to spot where the coolant spraying over your left boot is coming from.
Thanks for that, it did take me a little while to find the leak changed several components in my search. Didn't realise it was a common fault though wonder why?tony.mon wrote:From memory it's between 15 and 20mm ID, so get a length of 20mm ID and a couple of new hose clips and make one.
Thank god you don't have to take everything off to get to it. Doh! Last time I hope.
