EPS & PDF decal / sticker vector artwork
Enjoy!
EPS > http://cl.ly/code/0E1y0X1y282S
PDF> http://cl.ly/032D1K2C2k3a
PDF > http://cl.ly/251k1K0R110v
EPS > http://cl.ly/code/2L1p0E2I190N
PDF > http://cl.ly/2e2E1b3D2h2y
50th Anniversary Edition Decals
Preview
https://dl.dropbox.com/u/45241626/Tail%20Decal.pdf
Preview
https://dl.dropbox.com/u/45241626/Limited%20Edition.pdf
Preview
http://cl.ly/1a2m2r182R1y
Preview
http://cl.ly/30013n2q0R0n
Preview
http://cl.ly/2j3W3h1N331b
Vectorised tracing of Anniversary VTR number boards (to scale) - courtesy of macdee
The original white areas are painted white on the Anniversary model, which is the way I recommend - Use the file as a template or try getting white vinyl layer cut out (PDF is layered & labelled and editable in Illustrator). When placing vinyl and the vinyl decals on bike reference the pics of Yeti's bike.
Left Board.pdf > http://cl.ly/3b2S1e2e240u
Right Board pdf > http://cl.ly/0Q3s0O392K47
and front board carbon shapes > http://cl.ly/2x0z132x1j00 These go on the sidepanels and edge against the centre panel section. I've added tabs so top and bottom can be wrapped under out of view. Might need trimming at the top with a scalpel (I've ordered some vinyl and will test out)
