My firestorm won't start!!!
kev1982
Re: My firestorm won't start!!!
Post by kev1982 »
Ok, I can't remember for sure as it's been over a week since I last tried. But I think the squeaking was only there when the engine was running. As for the fuel smell in the oil, my first thought was piston ring failure and maybe that was causing the noise. It seems there is a lot of people way more informed than me, so I really hope your right and it is something relatively simple and repairable. I've waited years to own a storm and only been able to ride this one for a couple of hours!!! :confused :sick:
kev1982
Post by kev1982 »
Ok, so after not getting a reply from several messages and phone calls to Mr Hedges. I've been forced into putting the bike into a garage!! Initial ideas from the mechanic are that the timing may have jumped a tooth or two!! Although I am waiting for a definitive diagnosis. As soon as I know what it is, ill let you all know.
It'll be interesting to find out, the CCT's being changed to manual rule out valve meeting piston but that sounds like a possibility from what you're describing.
Can't help thinking, though, that it'll be a simple thing like a fuel tap diaphragm, or something like that.
Hopefully, anyway.
Let us know.
kev1982
Post by kev1982 »
I have finally sorted my storm and got it back on the road!!! :thumbup:
After a couple of hours in a garage, the diagnosis was bigend failure. So the manual cct's weren't to blame!!!
The cost of repair was going to be too much so I bought another engine off eBay and I replaced it myself. The problem now is it has the standard cct's on it now so I will at some point replace them with the ones that are still attached to the knackered engine.
Xenocide
Post by Xenocide »
Glad you're back on the road mate!
How come they failed? Oil starvation?
Mine burns a bit of oil (quite a lot actually..) so i need to make sure I check it regularly :(
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Trowbridge & Surrounding Areas Lawn Mower Servicing & Repairs
Me to
I check it as well as the tyre pressures
Before each ride :-)
