Leccy techie help needed for a little project....
ging500
Re: Leccy techie help needed for a little project....
Post by ging500 »
Xenocide wrote:
bazza696 wrote:then rather than a fiddle assembly to lift the trumpets, you are twisting the trumpet which will then allow it to lift. So you could fix the motor to one of the tabs on the trumept to pull and push it, of fit a mechanisum similar to what I have in my RC powerboat to turn the rudder.
I think I get you - like a flexible link that will allow up + down travel to go with it's side to side.
Reading this: http://www.sportrider.com/bikes/146_090 ... to_07.html
They just take the top off the trumpets at high rpm... Two things from that...
1) Can we just take the top off?
2) We do it via TPS... How does the VTR sense RPM for the speedo? Crank sensor? I should be able to figure out the speed of that and use that data too.... hmm.
I've played with an old abs sensor before and managed to get it to count the pulses and figure out a speed (wasn't calibrated) but it worked...
Also I was thinking, the TPS uses the bikes's power + ground then the computer figures out the throttle position by the difference between what's coming back off the wiper arm of the TPS and it's 12v+ line. Normally that wouldn't be a problem because you know what your input voltage is but with a bike it varies with the rpm of the motor (due to the stator - 12v-15v pretty much) so I'll need to find a way of passing the controller a reference voltage as we'll just be tapping into the TPS value rather than supplying our own known voltage.
Bloody complicated sometimes!
This is a very interesting (and complicated problem). After looking the yamaha system, i agree with xenocide tht they remove the top part of the trumpet. In doing this you would limit the need for lubrication. The only part would be the device tht moves the trumpet up ie the worm gear
Looking at the wiring diagram I think it's getting it off the speed sensor via the speedo and the Ignition control module.
Here's a coloured wiring diagram that may be of use to you.
http://www.mediafire.com/?wdkiixw52j303t6
Xenocide
Post by Xenocide »
If we were to go that way we could use some linear actuators and sink them into the top of the airbox lid..
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Trowbridge & Surrounding Areas Lawn Mower Servicing & Repairs
Xenocide
Post by Xenocide »
Looks that way - thanks for the diagram.
It (in turn) is getting it from the "ignition pulse generator" I assume which would be a pickup on the flywheel or spikey wheel on on the crank somewhere.
Yarp: Image
Gives a new test procedure too :).
'94 KTM LC4 400e
Bazza, that works fine- the only problems would be keeping it lubricated. Blown back petrol will wash off anything we put on, and it's not exactly simple to access and re-grease on a regular basis.
So for now I'm looking at a simpler rotating cam operating from the side lifting an actuating bar on a parallelogram arrangement to keep it in line.
Another alternative is the worm drive form below, but there's less room for the motor there- I'm pulling my bike apart today to measure the clearances to see where that actuator might fit.
The advantage with option 1 will be quicker actuation- I want it to be able to react as quickly as the throttle is rev'd, if possible.
But all input welcome, and I might mock up your suggestion to see how it could be done, without leaving spiral slots cut in the side of the stack, through which air will leak. Maybe a double thickness wall, with spirals cut into the outer one only? But I'd rather keep the amount of clutter inside the box to an absolute minimum.
Xenocide wrote:
1) Can we just take the top off? Yes, we can- but the lower section will still need a good transition radius for the air to flow over. This will be even more critical if the air is primarily flowing in from the sides over the lip. Also headroom is critical, and we have to allow for the fact that some people have std Honda filters, others K+N or BMC. Going upwards is difficult without raising the airbox lid, which means raising the tank.
2) We do it via TPS... How does the VTR sense RPM for the speedo? Crank sensor? I should be able to figure out the speed of that and use that data too.... hmm. Very possible. I was trying to keep the sensor data needed to a bare minimum at first, even thought of actuating the lifting mechanism via a left-hand twistgrip to test whether it worked at all initially. I'm conscious that ideally we end up with a fairly simple "How-to" that anyone who wants to can copy. The more simple it can be made, the easier it will be to make and fit.]
Also I was thinking, the TPS uses the bikes's power + ground then the computer figures out the throttle position by the difference between what's coming back off the wiper arm of the TPS and it's 12v+ line. Normally that wouldn't be a problem because you know what your input voltage is but with a bike it varies with the rpm of the motor (due to the stator - 12v-15v pretty much) so I'll need to find a way of passing the controller a reference voltage as we'll just be tapping into the TPS value rather than supplying our own known voltage. How about using a microswitch on the throttle cable pulley or connector bar instead?
Olbikeman- Yes, I think that's what the restrictor ring made of aluminium set into the inlet rubbers is for, but it's very crude.
Trouble is, you need a small diameter port for low speed running and a larger one for higher engine speeds, and I've never seen a satisfactory solution for that one which doesn't interfere with smooth air flow and knock some of the vaporised/atomised fuel droplets out of the stream, which would make accurate fuelling a nightmare.
Actually the intake rubbers could do with being remade smoother all the way through- the variations in diameter and steps aren't helpful.
If it weren't for the fact that the carbs are at different angles a machined aluminium or hard plastic one would be better altogether, I think.
Xenocide
Post by Xenocide »
I'm back!!
I've been ill for what seems like years now.
How did you get on with your fiddling tony? I got your pm but I can't visualize it :(.
'94 KTM LC4 400e
I've just had an email from Matt Wildee from PB saying they'd like to run a piece about what we have planned here.
Fame at last!
(assuming it works)........
Cool stuff tony look forwards to reading it, you do classify for the obsession feature :lol:
well done guys now you just need it to work :thumbup:
who's PB :confused mag or site.
seb421
Post by seb421 »
cybercarl wrote:who's PB :confused mag or site.
Performance Bikes magazine i would hope, would be cool as wombles to have a feature on your self and work's
Well done Big T & Gang
Cheers seb. I feel like a right knob, I should have been able to work that out, but it was almost 3 in the morning when I read it. Der.. :Ball Kick:
That would be well cool Tony. If there was an article regarding this forum, I would actually go out and buy there magazine. That issue anyway. :roll:
Project update, hows it going? Did you work out the mechanism.
cybercarl wrote: . If there was an article regarding this forum, I would actually go out and buy there magazine. That issue anyway. :roll: (:-})
I would be worried that an article covering this forum would focus on a bunch of middle aged blokes with
* various forms of midlife crisis and Ti / CF addictions
* Who spend more on modifications than the bikes are worth
* who spend too much time on e-bay
* Who argue pointlessly about what colour is 2nd fastest behind yellow
* Who have more failed relationships than failed CCT's
* Who get together to look at each others tool collection [I was going to say "look at each others tools", but that sounded too rude]
* who get over excited if woman joins the forum or sells cake :lol:
* Who cant organise a ride out with out someone falling off
* etc etc
and thats just the list of positive things :lol: :lol: :lol:
we are not going to come out of it well! :D
:clap: :clap: :lol: :lol:
That pretty much describes thing's :lol: :lol:
