I will update with some pictures when i next get it clean
Here is what has been done so far
Replaced
Previous exhausts - Standard Headers x2, Original end cans , Custom Made Race Cans, Blue Flame Single Port Evo's, Scorpion High mounts
Mirrors, its had a few
Forks, wheel (bent after Bike was Stolen)
Engine (1997 Engine) Original 2000 has Knocking crank
Carbs
Airbox
Subframe
Fairing Stay
Gear Lever (numerous)
Left rear set
Footrests Various
Fairing panels various over time
Brake and Clutch Levers (Various some for style most through bring dropped / crashed)
Side Stand - bent bike was stolen and crashed
Replaced hangers bent when stolen
Belly pans first powerbronze set on fire and melted all over the exhausts and floor
Petrol Tank's think its on its third, currently on the look for another
There is not a lot of the original bike left to be honest its a bit like triggers broom only the frame, rear wheel and swinger and shock are still there, the shocks going soon too.
Cosmetic
Upgraded Dash to LED's
Black Smoke New Style Fireblade Front Indicators
Clear Ducati 996 style rear indicators
Clear Rear Light lens
Repsol Fairings
Powerbronze Lower Fairing
Pyramid Undertray
Airblade Double Bubble Light Smoke Screen
Carbon Fibre Fender
Carbon Fibre Frame Protectors Top & Bottom
Carbon Fibre Engine Covers
Diamond Black Race Grill Mesh
Removed Pillion rests
Performance
RR3 Fireblade Forks, Front Wheel, Triple Clamps, Calipers, Bars
Titax Preload Adjusters
Yoshimura R&D Exhaust System + Hangers
Pipercross Race Air Filter
Two Long Intake Velocity Stacks
Modified /Gutted Enlarged Air Box Lloydie Special
Dyno Jet kit (#190 Mains, 5 clip on DJ needles, #50 Pilots, 2.25 turn on front mix screw 2.50 turn on rear mix screw)
TPS Sensor Calibrated to 500 ohms
6mm Shock Spacer
EBC SRC Kevlar Series Street Racing Clutch & Springs
Replaced HT Leads and Coils with 2003 CBR600 Inline Stick Coils > Thanks Benny!!
Quick Throttle Mod > Thanks Benny!!
HEL Braided Lines
Kagizume 330mm Wavey Discs
Brembo (RED) Pads
Other
CBR 954 Foot Rests
APE Manual Cam Chain Tensioners
Ambient temp gauge
Vacuum lines fitted for quick carb balance
New Style Regulator Rectifier
Castrol Power 1 10w/30 Semi Synthetic engine oil
X 2 Inline Fuel Filters
Michelin Pilot Road 3 tyres
Stahlbus Quick Drain Oil Valve
HRC Brake Tubes (Green Rear / Pink Front)
Oxford Sports heated grips
Special GLSR Titanium Timing Cover Bolts
Still to Fit and Do
WP Shock
Hagon Fork Springs (thanks marty)
Dash Gauges and Sensors
Replace Tank and repaint
Paint Wheels Repsol Orange
Get a new Number Plate
Fit Steering damper
Pad out the Seat
Get new Bar ends
Get a new quality Screen
Touch up fairing prangs
Get Spare Flywheel lightened
Take off subframe and paint black
Make up braced swingarm from spare blade and storm swingers
