lloydiecbr wrote:Just noticed you have a projector head light
Come on what's your list of mods ?
Hmmm, yea, the projector light is a Morimoto kit, if you do want to get it that would be the best place:
http://www.theretrofitsource.com/produc ... cts_id=927
Not sure how they can work it out with UK, but you may as well check on with them,
truly great people and very helpful, the projector is absolutely the best you can get anywhere, for more instruction and general know how also look at this link on the US forum, you will find it very helpfull:
http://www.superhawkforum.com/forums/mo ... ion-27804/
Here is the complete list:
- Morimoto Projector head light as you already know
- 07 CBR1000RR complete front end
- Tapered head bearings
- Added my own brackets for the radiators to shift them back due to the CBR front installtion
- Added brackets and moved the oil radiator down by 2cm to clear teh wire harness and other
- Cut the front farings to fit the new front
- 09 CBR1000RR front wheel and rotors
- 09 CBR1000RR rear wheel and rotor
- Clip Ons bars by Paolo Tarozzi and the risers are from Ducati ST3 (I was hoping someone could guess it)
- Lower fairing was part of a cracked ST3 front upper fairing that I put together with some fiberglass
- Auxilliary led lights under the front fairing 500 lumis each
- Rear shock bushing added on top to get the rear higher due to my height
- Additional starter/kill switch on the left bar used for projector light kill switch
- 07 CBR1000RR Kick stand(side stand). Replaced due to the poor flex design of the solid metal Kick stand and natural tendency of the VTR to leans too much plus the higher set up makes it even worse, the CBR kick stand with tubular design lighter, stronger, bit wider footprint and longer by 1 inch makes a perfect bolt on fix that I came up with!
- 520 Chain and sprockets, front and rear sprockets by Superlite ratio front 15 to rear 45 and I love it to my style of riding!
- Suzuki heavy bar ends for added stability of the front end
- Lighter footpegs, Had these for a while from another project bike, superlight and fitted perfectly, don't know from what bike though
- EBC HH brake pads
- Cut the mud guard and now the number plate is the mud guard
- MRA windshield touring version cut 2 inches down
- Longer mirrors, can't remember what manufacturer, but they working great, no vibrations and very stable.
- Front fender OEM fitted by me to the new CBR1000RR front, a little hit gun work and couple spacers and brackets
- Oh and I rebuild the forks and the brake calipers as well, they came to me in a very bad shape, I also rebuild the master cylinder, but never used it
I think I covered it all so far, more is coming, but that will have to be later, I have a long list for that as well............... I guess sense I already have the list here, I may as well just add to this thread every time I add stuff
You never see a motorcycle parked in front of a psychiatrists for psycho therapy. All I need is cycle therapy
