Yes your quite right Tony that's a vast improvement. Nice clean lines
I think the Persil is good. But with the persil broken up a bit with those clean lines by having a dark fairing lower and the bottom tail be painted like that, would be great.
And for Blue Storms they can have Frosties. That would be Greeat
I must confess that while photoshopping the albino beastie I was referencing the white SP1 which had the black on the tail, also remembered Tony had previously mentioned it as something he wanted to try and last time I looked he has done the same trick on his custard storm. (Edit, a bit more black on Tony's than I remembered)
I put some gaffer tape on the tail section to protect the paint when I went camping on it, but it sort of stayed there for two years.
But in the pic a couple of posts up I have sprayed the whole tail section graphite grey metallic, with a matching bellypan, but is still thins it down at the butt end quite successfully, I think.
tony.mon wrote:I put some gaffer tape on the tail section to protect the paint when I went camping on it, but it sort of stayed there for two years.
it looks like youve been spending time with macv2
Nope, his thin butt is nothing to do with me.
And I'd like to keep it that way.
No fence, Mac.
It's not you, it's me.....
