New bars
thumperslaw
New bars
Post by thumperslaw »
Fitted them Wednesday and went for a long blast. Time to think about them as they are higher then standard
Still in two mines if I like them :/
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Steve6088
Re: New bars
Post by Steve6088 »
Maybe you could mount them below the top yoke to make them lower, if there is space?
thumperslaw
Re: New bars
Thinking about it but would have some steering props?
K100 "flying brick"
Re: New bars
they look good compared to standard so that fulfills 1 of your requirements :thumbup:
they look to be higher where they mount to the forks, but have a steeper angle downwards .... so do you think your hands are back in the same place or still higher than normal?
Phimosis
Re: New bars
Post by Phimosis »
Thats a fair bit higher isnt it, wont be surprised if you get back ache...let me know if you do as im thinking of raising mine a bit...
She told me she was 16.
thumperslaw
Re: New bars
Thinking of selling them and buying some others to see what they would be like
K100 "flying brick"
Re: New bars
I ended up putting later model Storm bars on and it's surprising how much of a difference the small 5 degree lift makes. When put side by side with the old bars, I would say they are about 1/2 inch higher at bar ends.
thumperslaw
Re: New bars
Want to go lower now :)
K100 "flying brick"
Re: New bars
AS Steve6088 said, try mounting them below the top yoke.
thumperslaw
Re: New bars
Just brought other clamps now so I can now see them both on the bike.
K100 "flying brick"
bigtwinthing
Re: New bars
Post by bigtwinthing »
did you have to alter anything, hoses,cables etc?
thumperslaw
Re: New bars
bigtwinthing wrote:did you have to alter anything, hoses,cables etc?
Luck for me no!
K100 "flying brick"
thumperslaw
Re: New bars
Got second pair of clamps
Now they are lower then the other ones I brought
K100 "flying brick"
Re: New bars
Should make it easier to get your chin on the tank !
thumperslaw
Re: New bars
lloydiecbr wrote:Should make it easier to get your chin on the tank !
Slip stream is in for 2013!
The other clamps where to high for me
K100 "flying brick"
