One hot & one cold cylinder
- denisblackvtr
Can anyone tell me is it normal for the right hand exhaust to run cooler than the left one on tickover? Once the throttle is blipped they seem to be the same temp. Thanks in advance. Denis.
GAS GRASS OR ASS NOBODY RIDES FREE
Re: One hot & one cold cylinder
the standard exhaust headers favour the lhs at low rpm
its only when the pressure in the exhaust is increased but the engine picking up revs that it pushes more exhaust gasses out the rhs exhaust ,
- denisblackvtr
Thanks for that Lloydie, was a bit concerned but there was no smoke so thought (hopefully) there would be a simple answer.
+1 on what Lloydie said. It's totally normal. I think the restricor plate thing in the end of the header pipe has something to do with it as well, so as revs are picked up more pressure pushes past the restrictor and out the right can
My right hand pipe hardly works on start and tick over.
She told me she was 16.
You'll also get more condensation on startup from the LHS because any condensate will collect on that side due to the bike leaning that way towards the sidestand.
I had a gl1000 mark 1 goldwing that did this the left hand pipe used to rot cos all the water used to sit in there,tony.mon wrote:You'll also get more condensation on startup from the LHS because any condensate will collect on that side due to the bike leaning that way towards the sidestand.
