Just got my old blade wheel
thumperslaw
Post by thumperslaw »
Six spoke for the rear. Sprocket drive axle et
What do I need to do when fitting it to the storm
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Jonesey
Re: Just got my old blade wheel
Post by Jonesey »
Just put it on the bike, it's a straight swap.
Jonesey wrote:Just put it on the bike, it's a straight swap.
+1 same fitment
thumperslaw
Next up what about the front?
K100 "flying brick"
Stephan
Post by Stephan »
thumperslaw wrote:Next up what about the front?
VFR 750 94-97, CBR600F3
thumperslaw
Disc from the storm work I take it?
K100 "flying brick"
Stephan
Post by Stephan »
Yes, should be direct fit, same as Blade rear wheel.
Have a look in the stickys as I posted up what wheels fit
http://www.ebay.co.uk/itm/Honda-Firebla ... 27d031b1db
http://www.ebay.co.uk/itm/Honda-Firebla ... 27d031c4d2
very cheap, but remember they're normally a little buckled, factor in bearings and p/c or respray....
thumperslaw
Keeping my eye on them now.
Will have them painted any way
I want to keep the storm on the road so I'll use the storm wheels while i get them sorted
K100 "flying brick"
Stephan
Post by Stephan »
lloydiecbr wrote:Have a look in the stickys as I posted up what wheels fit
I believe you miss VFR750 93-97 in your list, like this one
http://www.ebay.co.uk/itm/HONDA-CBR-600 ... 2328470ae6
thumperslaw
How much!!
K100 "flying brick"
I didn't put that one in as no one confirmed it fitted without mods
Or if they did I forgot !
Stephan
Post by Stephan »
bearings, brake discs, and spacers, are the same for VTR1000F and VFR 94-97, CBR600F3 as well, you can verify this. No offense ... :-)
i doubt you'll find any cheaper than £50, they normally go for around the £100 mark. personally i'd snap it up, make sure you ask the seller about its condition first tho, older front wheels are usually slightly buckled.... :(
