CCT's changed to manuals, now the occasional backfire
weasel
Re: CCT's changed to manuals, now the occasional backfire
Post by weasel »
Thanks everyone
I started the bike up last night and it didn't make that strange sound on startup (I'd say it's like a hollow metallic cough) and I ran the bike up to temperature. Then, at around 80 degrees c I turned the bike off and started again and then I get the cough sound, so I think like you say Woaty, things have expanded with the heat. I backed off the front tensioner a bit and this appears to have rectified that problem. I backed the rear off a little too.
I'm pretty confident now that it's all ok. There is still a background tick, but I still think I might be paying too much attention to this as it very faint, and as Cybercarl pointed out, manuals do sound different to the originals.
Cheers everyone,
Gav
When you say cough are you sure this is not just the carbs spitting back. I think you have got/had too issues going on here. The first is the manuals where a bit tight, and two, a bit of carb cough. If it is your carbs spitting back then don't worry about that for now that is a separate (tuning) issue. It's nothing to worry about and can be sorted at a later date. What is important, is that you have your CCTs done to the right tension. :thumbup:
weasel
Post by weasel »
Carl,
I think I might have confused things by describing it as a cough. It's a difficult sound to describe, but it seems to be cured by slackening the front CCT
Cheers,
Gav
All good then :clap: :clap:
Now all we need is some nice weather. :thumbup:
weasel
Post by weasel »
Nice weather, and new silencers!
weasel wrote:Nice weather, and no silencers!
That would do it, sho' nuff.....
