I havent lost any mpg and it pulls fine just this strange hessitancy when on the power and going over bumps ?????
I ve checked for loose connections etc....... but all seems fine
Diabolus wrote:http://www.ronayers.com/Fiche/TypeID/26 ... /FUEL_TANK
just had a quick look
hose #29 was not conected and resting ontop of the cam coverso that may explain the smelly bike issue.
Agree.cybercarl wrote:
I'm not sure if that's a good idea joining the two together. There's a reason Honda only have one vacuum. Also having them joined together like that is going to have each cylinder conflicting with each other. If your going to join them like that then put something in the middle of the brass tube, so your basically capping each side off.![]()
