LHS Switchgear
- Miztaziggy
LHS Switchgear
How the hell do you remove it?
I can only see 1 screw underneath, but it wont come apart...I dont want to force it too hard unless I break it.
Re: LHS Switchgear
There's another screw tucked away towards the front of the clamp - fine tipped short handle works well
Re: LHS Switchgear
yep two Philips head screws on the under side and remember to remove the clutch switch wires
- Miztaziggy
Re: LHS Switchgear
Oh right ok thanks guys, will go have another look.
Not sure which are the clutch switch wires though.....
Re: LHS Switchgear
little spade connectors off the back of the clutch mount.
- Miztaziggy
Re: LHS Switchgear
Thanks guys, yeah I found them when I finally found that other screw. Couldn't see it for looking.
Couldnt get the 2 parts separated though as the cable going through the bottom half is too tight to let you get at the screws inside. Doesn't matter, I still fixed what I was trying to fix anyway.
Re: LHS Switchgear
job well done then
- benny hedges
Re: LHS Switchgear
quite fiddly in there isnt it once you take it apart lol!
surprising how many parts there are in there
- Miztaziggy
Re: LHS Switchgear
Yeah it does look that way mate. As I say, I couldnt pull the 2 halves far enough apart to be able to get a screw driver in to take it apart further. I reckon if I did, it could have been one of those jobs where it is a nightmare to put back togetherbenny hedges wrote:quite fiddly in there isnt it once you take it apart lol!
Re: LHS Switchgear
Springs spring to mind, or is that over the garage floor.
Re: LHS Switchgear
Yep. Once you remove that small brass plate inside, there's a spring and detent ball that leap out and scurry under the workbench, or if you're working al fresco, somewhere on the lawn.
That's where a magnet on a stick comes in handy.
- Pete.L
Re: LHS Switchgear
You work out on the lawn naked?
Why doesn't that surprise me Tony?
