Thanks, will get some of that, spent more time working on it than riding it.darkember wrote:Autosol for the cans
Couldn't you cut the melted section out & insert a slightly smaller diameter section into the 2 endsscouse645 wrote:Thanks, the pipe is 1mtr long and the bit thats melted is 11inch from the tank, so it wouldn't be long enough if i cut that off to reach the belly pan.
Could do that, will have a look around online for a new one.darkember wrote:Couldn't you cut the melted section out & insert a slightly smaller diameter section into the 2 endsscouse645 wrote:Thanks, the pipe is 1mtr long and the bit thats melted is 11inch from the tank, so it wouldn't be long enough if i cut that off to reach the belly pan.
ok thanks, will sort that tomorrow as its getting dark.cybercarl wrote:It doesn't even need to reach as far as the belly pan. As long as it's hanging down out the way. Just trim it down and have it hang loose further back down the side of the frame somewhere. In fact it's better if it's slightly shorter as there is less risk of it getting blocked by any crap or water that may sit in the bottom of the pan.
Never thought of that, ordered some new stuff anyway, thanks all for helping.tony.mon wrote:Turn it round- doesn't matter if the scorched section is at the lower end.....
