Airbox
scouse645
Airbox
Post by scouse645 »
Hi, i know kemper162 asked about the the sponge bits in his airbox were no good yesterday, when i took my air filter off mine didn't have anything in at all :? is there a reason why someone would take them out? will any sponge be ok to put in there?
Re: Airbox
It could be one of two reasons as to why they are not there. One they have just been left out by someone or two they have totally disinterested and have been sucked into the carbs and bits fallen out the holes in the bottom of the airbox.
Any foam is OK but try to use something similar that does not have the air holes to compacted together as it will possibly restrict the airflow and preferably something that is resistant to chemicals. As mentioned in the other thread some air filter foam or aquarium foam filter material is ideal. Also give them a light coat of oil before putting them in place.
scouse645
Re: Airbox
Post by scouse645 »
cybercarl wrote:It could be one of two reasons as to why they are not there. One they have just been left out by someone or two they have totally disinterested and have been sucked into the carbs and bits fallen out the holes in the bottom of the airbox.
Thanks for your reply, i will sort that when my new air filter arrives, never enjoyed myself as much as working on this bike, not too technical.
scouse645
Re: Airbox
Post by scouse645 »
Does the foam go in those two triangular shaped bits?
Stratman
Re: Airbox
Post by Stratman »
scouse645 wrote:Does the foam go in those two triangular shaped bits?
Yep
scouse645
Re: Airbox
Post by scouse645 »
Yep
Much obliged.
Re: Airbox
yes it does mate. i have to say when i first bought my bike several years ago, it didn't have those foam bits either, if i'm honest, i didn't think it made any difference to how the bike ran.... :confused
but its better to have them in or blocked off.
this will do you, its a touch on the thick side tho
http://www.ebay.co.uk/itm/GGP-FOAM-AIR- ... 20d236a0af
Re: Airbox
It wont make a difference to how it runs as all they are doing is filtering the atmospheric air that goes into the carb diaphragm's. So is basically just stopping any particles from getting into the carbs. As for blocking them off, no you can't do that or you will encounter problems unless you leave the hose disconnected underneath. :roll:
scouse645
Re: Airbox
Post by scouse645 »
bigspanishmarty wrote:yes it does mate. i have to say when i first bought my bike several years ago, it didn't have those foam bits either, if i'm honest, i didn't think it made any difference to how the bike ran.... :confused
Thanks for the link, i will order some, :D
tattoo
Re: Airbox
Post by tattoo »
I have no problems, mine are blocked off with rubber caps that are the same shape and the pipes still connected...I do have a K&N filter fitted though if that makes any difference..
Re: Airbox
The rubber caps don't block the airflow http://www.vtr1000.org/phpBB3/viewtopic ... 27#p266574
tattoo
Re: Airbox
Post by tattoo »
There wasn't any filters I them when I got the bike so never bothered getting any...filter sponge is now on my shopping list though
scouse645
Re: Airbox
Post by scouse645 »
tattoo wrote:There wasn't any filters I them when I got the bike so never bothered getting any...filter sponge is now on my shopping list though
I ordered the ones bigspanishmarty gave the link for, they emailed to say that it was posted, not a bad service.
darkember
Re: Airbox
Post by darkember »
Agreed part of the K&N kit are the rubber plugs to block off these ports, no mention about the pipe under the box. Would it harm to block them off regardless??
Re: Airbox
Well, yes, as these are allowing the air on the internal side of the diaphragm in the carb to escape to atmosphere.
So the diaphragm won't move properly.
Unless you do as I have and blank off the airbox inlet, removing the corners, plating across them, so increasing airbox volume, and then placing small foam caps on each diaphragm exhaust pipe....
Don't expect another 20Bhp, though, it's part of much bigger work. On its own it won't make any difference you can notice.
