FRONT END
clochies
FRONT END
Post by clochies »
HELLO, JUST BOUGHT A VTR AND THERE IS I SLIGHT CRACKING NOISE COMING FROM FRONT END UNDER HEAVY BRAKING ,NOT SURE IF IT IS HEADSTOCK BEARINGS OR
WORN BUSHES IN FORKS ANY SUGGESTIONS ? THANKS
Re: FRONT END
Greetings
Clunky noise can be head bearings so begin there. And as the forks are a bit soft you might want to respring to suit and service them anyway while you're giving it an overhaul, replace bushes, oil, seals etc.
Downloadable PDF service manual is available from the workshop knowledgebase.
P.S. Image
simo
Re: FRONT END
Post by simo »
+1......Hi and welcome to the Forum. Hope you get sorted without too much expense .
Theres A Hare in The Turnips.
Re: FRONT END
welcome to the forum dude, please take the time to read thru the workshop section, most of the issues and answers regarding the firestorms common faults are covered.
good luck finding the source of your problem.... :thumbup:
Re: FRONT END
if you feel the clunk as soon as you hit the brakes then the head bearing need tightened. if the are knotchy then the will need replaced and you should use taper rollers, but if they are just slack then nip them up a bit and carry on
Re: FRONT END
If you feel the clunk at the start when breaking then its head stock bearings
If the clunk is at the end of heavy breaking just before you come to a stop its fork bushes .
Re: FRONT END
Welcome aboard clochies :thumbup:
Good advice already been posted on your question,
Xenocide
Re: FRONT END
Post by Xenocide »
Mine was head bearings - the PO was a self confessed wheelie monster so that's probably got something to do with it :)
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Trowbridge & Surrounding Areas Lawn Mower Servicing & Repairs
Re: FRONT END
You should also check the front mudguard fittings, if they're loose it will rattle.
Re: FRONT END
Are the brake hoses secure (particularly braided steel ones)? If not they may move and strike the mudguard/fairing as the forks compress.
