How to: fit a fag lighter
Ckennedy
Post by Ckennedy »
I know this is an easy thing for most of you to do but for those who are not so good with electrics/mechanics while I fitted mine today I thought I would take some pics and do a quick how to guide for those out there who require a bit of guidance.
First thing to do is remove the seat to gain access to the battery:
2nd: Get a waterproof fuse holder and fit a 10amp fuse
3rd: Strip the ends off of some twin core cable and fit a ring terminal to each wire for the battery screw to go through.
4th: Cut through the power wire and fit in the waterproof fuse holder using heat shrink terminals. Remember to heat these with a lighter to make waterproof.
5th: Cut the wire where you want to mount the on/off switch:
6th: Cut another piece of twin core to go from the 2nd terminal on the on/off switch and fit a spade terminal. This is the power feed for the lighter. The other wire goes is negative and is crimped with the negative wire from the battery.
7th: Fit your wires to the switch. Power in to number 1. Power out to number 2. Negative from the socket and the battery to number 3.
8th: This is where I drilled the hole for my switch. Just below the seat between the frame and fairing. If you decide to use this place be careful of the wiring loom and the battery. Drilling through either of these will cause a nasty mess.
9th: Connect your ring terminals to the battery and test with a charger to your satnav/phone or what ever.
I forgot to get a pic of the switch in place so you will have to use you imagination. Hope this will help someone out there at some point.
Re: How to: fit a fag lighter
If its fitted under the seat how the fook can you light ya fag on the move ?
Ckennedy
Post by Ckennedy »
I was not planning on using it to light a fag. I would also like to know how you would light a fag with your helmet on?
Virt
Post by Virt »
Ckennedy wrote:I was not planning on using it to light a fag. I would also like to know how you would light a fag with your helmet on?
Flip up visor :lol:
Flip up lid :-) not that I smoke anymore lol .
Ckennedy
Post by Ckennedy »
Alright smart arses :lol:
you made a smart job of that mate, i like the fact it has an on/off switch aswell, if ever i take my bike touring, i'll deffo fit one of these, sorry let me rephrase that, carl will deffo fit one of these.... :lol: :lol: :lol:
Ckennedy
Post by Ckennedy »
:lol: :lol: It is an easy enough job. Its all put together outside the bike so space is not an issue. Anyone can do it :lol: But then again if you did it what would Carl have to do :lol: :roll:
When I was despatch riding around London I used to smoke while on the bike in slow moving traffic. The only problem was the hot rocks blowing back in my face :lol:
seb421
Post by seb421 »
Barry Sheene, Dads got some pictures of him on the grid having a smoke via a hole drilled in his helmet that he used to tape back over, extreme!
i have one of these wired direct to the batt and cable tied to the lock barrel so its in front of my key, don't bother about a switch a gps and phone drains wombles all
http://www.ebay.co.uk/itm/300776312621? ... 1439.l2649
i just used a bike battery in my room for 5 days charging a phone, using it down to like 30% then plugging it back into to the bike battery to charge it as i had broke my mains charger
there is still juice in the bike batt too :thumbup:
i was going to bin the batt awhile ago as it did not have enough umph left init to turn over the fireblade but off a single charge can power the phone for 5+ days with heavy use so if i go camping with the bird using the car ill charge the bike batt and take that in the tent as a away from home mains charger :thumbup:
Winner Winner Chicken Dinner!
Redthunder
Post by Redthunder »
Sorry to change thread slightly, I now have a similar undertray. Can you advise how you have secured the CDI boxes to stop rattling around. I see they are cable tied together? Thanks
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
Destined4bikes17@gmail.com
Ckennedy
Post by Ckennedy »
Cable tie together and then a cable tie around the both of them to the sub frame. I could have thought of other ways but at the time I couldnt be bothered to think :lol:
Redthunder
Thanks. Will do for now!
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
When I get my undertray on I'm thinking of using some foam, the kind you get in flight cases for cameras or whatever. I can then cut out bits for the electronics, toolkit etc to sit in.
Ckennedy
Post by Ckennedy »
That's what I was thinking of doing Carl but I didnt have any at the time :lol:
