Fitted a single side swing arm from a 2000 VFR 800. Building custom handlebar setup and also put on a tailpiece from a 2009 R1.
Spent most of today changing the exhaust system. This is necessary as the rear shock gets totally in the way of the rear header. Many guys doing the SSSA conversion go with a single exhaust can on the left but I decided to have mine under the tailpiece but more to the sides as it's too easy to run into clearance issues with the tire if they in the centre.
Here is where she's at:
