This is them on the bench
They then attach and bolt to the swingarm (excuse this as it is a spare I have for modding later) using the original M8 adjuster thread.. the square bit on the end slides down onto the swingarm and leaves the radius to but up against the radius that is there...The travel and adjuster markings run the same length as the swingarm allows (24mm)
The standard spindle is too short now with the addition of the 10mm adjuster either side
But the spindle from the swingarm that was kindly donated will fit perfectly once I have added the titanium spacers and nuts
It seems to work well by just turning the "captive" caphead in the back of the adjuster, again these will be swapped for nicer items..
So there you go.... anyone see anything I could do a little or a lot better or should be re-designed which could make these a little better?
I also understand I will be making new spacers on the inside of the swing arm a little thicker than standard to fill the gap of the original adjuster that is no longer there..
Thanks for any input
