gl_s_r wrote:Black chrome..... or even better a nice black oxide?
Oh don't !!
Just to add to the confusion, Titanium bar :biggrin
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40
:lol:
Actually I like the idea of making Carbon hangers but I think for it to be sturdy enough those kits are not the best unless you could get vacuum pressure treated or something. :think:
:erection:
Fondled various goodies... :shifty:
Gave her the couple hundred mile check over and re-tightened a few things......
No it's time to take her out to the road that tried to kill me when the shock broke...... :eek2 :lol: :lol:
Wish me luck :thumbup:
8541Hawk wrote:Gave her the couple hundred mile check over and re-tightened a few things......
Good luck... :thumbsup:
gave the bike a good clean and spent a little time on the headers again. ready for a trip to the dvla tomorrow morning... :thumbup:
Raged it to and from work :-)
lloydie wrote:Raped it to and from work :-)
enough of virts anus, what have you done to your bike today........... :lol: :lol: :lol:
Virt
Post by Virt »
Started making the hangers
Taped up for mock up . I'm welding them up Saturday :-)))))
nice tape work Lloydie. :thumbup:
in my opinion they will look better if the upper mount goes back to the can strap as well as the lower one, that is the more classic shape.
and if its all steel some nice brazing might work better if you are doing it your self.......an amature braze is stronger than an amature weld
I have cut the top tubes but I'm undecided which one u like more !
I can weld better than braze but I'll only be doing the tacking and my mate will be doing the welding as I haven't do it in years and I want good penetration !
mik_str
Post by mik_str »
Dropped the forks 4mm in the triples; bike felt a bit loose when getting up to (very) high speed (which I very seldom do, but alas, I want it to be very planted when I do). Further to comments from Roger about how the overly long rear shock on the early racing VTRs caused this very condition, I trimmed the shock shim from 5.3 to 4.1 mm, which helped. However, I decided to drop the forks a bit (for a similar effect) this time around in the hope of getting everything perfect.
As an aside, this should help me to gain a bit of ground clearance (not that I really need it), as well as raise the CG slightly for a quicker turn-in...... Depending on how things work out, I may drop them some more (have 6mm left to go), then shim up the rear again to keep the geometry the same while raising the cg some more...... some day I will get there.... perfection :)
P.S. am waiting for my Zcoo front pads to arrive.... quite looking forward to trying those babies :)
mik_str
Post by mik_str »
lloydie wrote:I want good penetration !
sounds like you`re making a porn movie, lol
