Regulator/Rectifier
Regulator/Rectifier
Dumb noob question here. I have read the threads on replacing the standard smooth reg/rec and can see suggestions for Yamaha ones etc or the CBR 125. Does the later, finned version for the VTR not bolt straight on using the existing holes/wiring etc.? Basically looking for a totally plug and play solution.
Re: Regulator/Rectifier
Yep the later finned ones plug right in as do the cbr125
The yamaha r1 regs are crap I had two fail in two years so I suggest you stick with Honda r:r
Cheers fella, I will get one ordered off eBay
If that's the case, I'm not going to tempt fate by mentioning which one I'm usinglloydie wrote:Yep the later finned ones plug right in as do the cbr125
- benny hedges
ive got a good finned one spare - £20 plus post.ESPER_996 wrote:Cheers fella, I will get one ordered off eBay
it's from a cbr1100 blackbird not the cb125
regards fitting - it's a lot bigger physically than the original pos so you fit it using just the one bolt hole, in the same place as the original.
the original plug goes straight in.
agree with lllllloydy, the yam ones can fail.
the fad of using a yam one comes from a random page that someone posted showing how he butchered his storm wiring loom and got an r1 rr to fit.
the result was loads of people copied him, for some reason believing they are better.
yes, they are better than a broken one but they are no more reliable than the old style honda regs!
Benny. As I've still got the original R/R on mine (it's done 38.000 miles 1998 model) I think I ought to have a replacement ready for the much talked about failure. So if you want to sell it I'll have it please
redvtr
- benny hedges
no probs mate, yours if you want it.neil wrote:Benny. As I've still got the original R/R on mine (it's done 38.000 miles 1998 model) I think I ought to have a replacement ready for the much talked about failure. So if you want to sell it I'll have it please
i wouldnt bother waiting for the old one to fail btw - just keep the oem as a spare in case a mate gets caught out. fit the new one asap to be sure
Thanks for the R/R. I think I've pushed my luck with it I'll fit it for peace of mind. PM me details of how to pay
redvtr
get rid of pronto...
Me neither. and I have badly wired it with crimp terminals rather than solder.If that's the case, I'm not going to tempt fate by mentioning which one I'm using
At the end of the day any of the older style R/R's can fail whether it's from a later Storm, CBR, R1 aftermarket or whatever. The issue is not the make but the design and the way it operates. If you want a solid R/R then you have to go for the MOSFET technology but then your looking at spending close to £100 by the time one has bought nice waterproof connectors. But anything is better than the original as in wicky's pic.
Thanks for the replies guys. Are all the finned Honda ones physically bigger or are there any direct like for like replacements?
- benny hedges
afaik they are all larger, but they fit just fine.ESPER_996 wrote:Thanks for the replies guys. Are all the finned Honda ones physically bigger or are there any direct like for like replacements?
http://www.ebay.co.uk/itm/HONDA-CBR-125 ... 25802d501fESPER_996 wrote:Thanks for the replies guys. Are all the finned Honda ones physically bigger or are there any direct like for like replacements?
http://www.ebay.co.uk/itm/rectifier-reg ... 51a35e46a7
http://www.ebay.co.uk/itm/HONDA-CBR125- ... 4d01cb756b
- cliveyandrews
- Contact:
The CBR125 bolts straight in - uses both bolt holes, you can be sure of a good earth then....ESPER_996 wrote:Thanks for the replies guys. Are all the finned Honda ones physically bigger or are there any direct like for like replacements?
Sent from my iPhone using Tapatalk and my fat fingers and thumbs....
Audi, Vide, Tace
Audi, Vide, Tace
Nothing wrong with crimped connectors IMHO, after all every original terminal was/is a crimped one, providing you use a good quality crimping tool such as a ratchet type.cybercarl wrote:Me neither. and I have badly wired it with crimp terminals rather than solder.If that's the case, I'm not going to tempt fate by mentioning which one I'm using
Personally I would say renewing the spade connectors on the wiring loom is a good idea when fitting a replacement rectifier, especially now the wiring is getting on a bit. By cutting the old ones off you can use a new nice fresh bit of wire. Just make sure you use a good quality crimping tool if you do decide to do that, as I've mentioned above.
