P1's in need of help beastie
Running very lean I think
Re: P1's in need of help beastie
What's in the carbs at the moment, what's your set up? Needles, jets, air filter etc. That shoots right off at at 4 thou. You recent engine mods would have made a difference so you need to get them carbs dialled in to suit.
I believe it's been dyno jetted and running k&n filter, no idea what needles, jets etc are in there.
The bike as it stands now :-
carbs - dyno jetted - no idea what is used
cbr stick coils
k&n filter
inlet cams replaced with exhaust cams
delkevic 8" stubby cans
cbr stick coils
k&n filter
you need to get it set up soon before you damage it running it lean like that .#
try sticking stock air filter back in
i would stick the standard filter in a a quick fix, that will be worth 1 to 2 AFRs as that how much it richened mine when I swaped it on our dyno day
If you don't want to go digging in and playing with the carb settings for a quick fix I would ditch the K&N and put a standard filter in and this will more than likely get rid of the 4thou
and will also richen things up for you by giving things less air flow. I wonder if the slides have had the extra lift hole drilled out according to the dynojet destructions.
Al beat me too it
Al beat me too it
was going to ask if going back to standard filter would help any, not overly keen on pulling the carbs apart and not being able to get them all back together again
cheer's
cheer's
thats yellow bikes vs black for you Carlcybercarl wrote:Al beat me too it![]()
but green was there firstAMCQ46 wrote:thats yellow bikes vs black for you Carlcybercarl wrote:Al beat me too it![]()
are we talking about Virt again?lloydie wrote:but green was there firstAMCQ46 wrote:thats yellow bikes vs black for you Carlcybercarl wrote:Al beat me too it![]()
might as well beAMCQ46 wrote: are we talking about Virt again?
