Misfire...
BigDaz1982
Misfire...
Post by BigDaz1982 »
Hi peeps I have a 99 storm with 30k, I havent had it long but have noticed that it has a slight misfire at high revs when under load? its bloody annoying as when i go to overtake something it misses :confused
Any info is welcome thanks :D
99 Firestorm- High level scorpion cans (LOUD!!)
01 929RRY Fireblade- Blue Flame race can
98 SV650 s - Art race can
91 DT125r - DEP ehxhaust system
Miztaziggy
Re: Misfire...
Post by Miztaziggy »
Hi mate, I posted something ages ago about a misfire at high revs.
I tried all sorts to get it fixed, but it ended up being crap fuel in the tank.
Try that first. Empty it and refil with super.
If that doesn't fix it, try:
Check coils and leads within tolerance - check with ohm meter against manual stated values
Check plugs
Check compression
Check carbs - split in diaphragm, blockage somewhere?
BigDaz1982
Re: Misfire...
Thanks mate il check all these out! Ive also been told to check the side stand sensor.
Doin my nut in..... :confused
Miztaziggy
Re: Misfire...
Oh yeah, that was another one, the side stand sensor, but it's probably a last resort.
Do what I didn't, start with the easy one - fuel
Next easiest is the plugs, then leads and coils, then carbs, compression (if you have the kit)
