mattblackone
Post by mattblackone »
Here you are just picked up 10, M8x45 m/m stainless for £2.39 for the 10 from a local supplier i use just need to polish and fit them
Bill
Thank you and I've updated the post .
mattblackone
lloydie wrote:Thank you and I've updated the post .
sorry forgot to add the shoulder on the bolt cant be any bigger than 20m/m or they wont torque correctly
Bill
Top tip. :thumbup: I can see you fitting right in on this forum.
mattblackone
cheers mate always a bit unsure what to post when a newbie on a forum in case its been posted before
Bill
Virt
Post by Virt »
Bill
We love repeating ourselves here, don't worry.
Virt wrote:
Bill
Piss off Virt you 'Kin tw@ !
Virt
Post by Virt »
Steal your joke did I? :lol:
No.
I would have placed the same reply to anyone who had posted that...
mattblackone
Here you go a huge improvement over those horrid torx ones and for £2.39 a bargain as well
a few tips for those who might be a bit unsure about doing it
Do one bolt at a time
If the bolts you get are a bit long and you need to cut them down screw a nut on before you cut the bolt when you screw the nut off it will re-align the end of the thread so less chance of damaging the thread in the caliper
if you put any copperslip etc on the bolt make sure there is none on the end or it could hyd lock and not torque properly
sorry if that seems a bit obvious but i do know of one lad who took all 4 out and then wondered why he had a pool of fluid on the floor
Bill
Fitted the bolt kit
And a lightened flywheel
Ckennedy
Post by Ckennedy »
Looked at photos of mine and parts on the internet. Bout as much as I can do at the minute :( got sent home from work after a trip to the hospital due to a rather somehow infected elbow :?
lloydie wrote:Fitted the bolt kit
:erection: :thumbup: :)
Cut a slot out of the brace to clear the shock...
Should that be enough to clear the shock ol' wise ones? :) :)
Yes, that's fine, but check with one of the wise ones as well, just to be sure.
tony.mon wrote:check with one of the wise ones as well, just to be sure.
You're too modest :thumbup:
Cheers, all ready for some metal sowing then :)
