Another noob.
Re: Another noob.
Yep 8.12 of the manual in the workshop
- PARSLEYRIPPER
Re: Another noob.
Crikey I started my apprenticeship in Norton, lost my virginity to a girl from Norton and bought my second bike from Austins bike shop in Norton. JesusTheLump wrote:Yes, in Norton.
Sorry I know it was off point just had to say something.
- shaggy-doo
Re: Another noob.
Sounds good, looking forward to a ride-out if I can just get ONE of my bikes running again. The VFR is refusing to start, it has some kind of electronics issue, hope I haven't fried the ECU.Hi mate I'm not far away south of York ,a few members here abouts , if you need any help give me a shout ,go to squires a lot if you ever fancy a run out ,yorshire run is may next year have a look in runs/events,by the way what colour is it (red is best).ady f.
Re: Another noob.
Ok, so after all that...
I just bought an old engine off e-bay. So just need to slot it in.
Re: Another noob.
What mileage is on the replacement ?
Re: Another noob.
Apparently it has done 29 000 miles, so a bit less than the old engine.
Re: Another noob.
Somebody must have a strong back putting that VTR engine in there like that
Good luck with it all,
Re: Another noob.
Right, so here is the update.
Tried and failed to get the old engine out, (WD40, heat and a very large lump-hammer failed to shift the front engine bolt) so decided to swap out the front heads instead. Bought a head gasket from David Silver, was the same price as copy gaskets from e-bay, so why not. It was pretty straightforward, and the bike is back together and running. The new head does seem to clatter it's valves a bit, but perhaps I just didn't notice with the old engine, I am a bit paranoid now in case the engine decides to commit harakiri again. I don't want to ride it much until I get manual tensioners installed.
Re: Another noob.
Well done, good work
Fit stoppers to the std CCTs and then you have peace of mind for free
Re: Another noob.
Take a look at this if you've not already:-TheLump wrote:How do you make stoppers?
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=19416
