Virt
Posts: 6793 Joined: Wed Dec 12, 2012 12:35 pm
Post
by Virt » Wed Nov 20, 2013 5:57 pm
Bike keeps cutting out on idle. When moving it's fine, but if I stay on idle it struggles to keep going. Haven't heard anything go bang, it just cuts out
Any ideas? It was fine while it was warming up. It's only just started, so I'm sat at the roadside waiting for traffic to die down before I even think about turning it back on.
Thanks
Sent from my iPhone using
Tapatalk
Posts: 7895 Joined: Sat Feb 11, 2006 2:43 pm
Post
by Wicky » Wed Nov 20, 2013 6:01 pm
Make sure idle is set to 1,200rpm.
Virt
Post
by Virt » Wed Nov 20, 2013 6:01 pm
It's idling at about 1250-1300
Tapatalk
ging500
Posts: 540 Joined: Thu Mar 17, 2011 8:00 pm
Post
by ging500 » Wed Nov 20, 2013 6:02 pm
Have you been riding in the rain?
Posts: 5651 Joined: Sun Jun 30, 2013 2:28 pm
Post
by Jamoi » Wed Nov 20, 2013 6:02 pm
How often has it cut out?
Mine used to cut out, so I turned up the idle with the idle screw (located on the right in the triangular section of frame)
All is fine with a 1200 - 1350rpm idle.
Jamie
Virt
Post
by Virt » Wed Nov 20, 2013 6:04 pm
There was a thunderstorm here 15 minutes ago ging
And it's done it twice since I left work. Each time I stopped at a junction. Did it 3 times this morning. Other than that it hasn't happened. I know spark plugs and air filter need replacing, that's Sunday's job. Could it possibly be that?
Tapatalk
Post
by Jamoi » Wed Nov 20, 2013 6:07 pm
You could pull the front spark plug cap off and try drying it out if you think water has made its way in there.
If it runs, just ride it to Ali's before you have a paranoia induced breakdown!!
Jamie
Virt
Post
by Virt » Wed Nov 20, 2013 6:08 pm
It runs but traffic is currently very heavy and Leamington drivers hate me filtering. So it's rarely an option. I don't want to constantly have to start the engine as I don't want to drain the battery
Tapatalk
Post
by Wicky » Wed Nov 20, 2013 6:12 pm
Have you got Recovery provision?
As suggested check the front spark plug hasn't got filled with water past the rubber.
...spark plugs and air filter need replacing...Could it possibly be that?
It won't help if they are in poor condition.
Post
by Jamoi » Wed Nov 20, 2013 6:15 pm
Virt wrote: It runs but traffic is currently very heavy and Leamington drivers hate me filtering. So it's rarely an option. I don't want to constantly have to start the engine as I don't want to drain the battery
Tapatalk
Don't let the bike idle then, or turn the idle up with the screw.
Jamie
Posts: 16742 Joined: Mon May 11, 2009 4:54 pm
Post
by AMCQ46 » Wed Nov 20, 2013 6:18 pm
agree ... set the idle higher and then get to my house
Virt
Post
by Virt » Wed Nov 20, 2013 6:18 pm
No water in the spark plug area. And no recovery either.
Tapatalk
Virt
Post
by Virt » Wed Nov 20, 2013 6:35 pm
Just been on the phone to my dad for any ideas while the traffic died down. Tried starting it and there is a clicking/tapping under the tank...?
Tapatalk
Posts: 3041 Joined: Mon Jul 25, 2011 4:15 pm
Post
by Duffy1964 » Wed Nov 20, 2013 6:39 pm
Don't try and start it again Virt, sounds like the CCT has gone, Get Al to check it ASAP matey
Post
by Jamoi » Wed Nov 20, 2013 6:42 pm
Duffy1964 wrote: Don't try and start it again Virt, sounds like the CCT has gone, Get Al to check it ASAP matey
+1
If you're in doubt, try and get someone to recover you or find a friend with an AA or RAC (etc) card.
Jamie
