Bike cutting out
Re: Bike cutting out
Is it the starter solenoid on the left hand side. If that only clicks when you try and turn it over then sounds like your battery is getting flat. You'll need a jump start or a bump start (fun in the wet!). If you suspect its more of a bag of nails noise then DON'T start it and get immediate help.
leevtr
Post by leevtr »
Reg Rec ???
chric
Post by chric »
I had the same issue young virt with a new battery was getting worried then one day it just died.
now i have the motobatt in nowt stops it brilliant they are :thumbup:
Virt
Post by Virt »
Click was me being stupid. I pulled the spark plug lead to check for water, there was none. I stuck it back in. I got paranoid and pulled it out to make sure it was in properly, but forget to stick it in. Hence clicking sound. Plugged it in and it vanished, rode it to Al's with no problem (held the throttle at 1500rpm whenever the clutch was pulled in) and had the stopper mod done. Bike is now fine, CCT's weren't the issue at all it seems. I've just learnt how paranoid and protective of this bike I can be.
Massive thanks to Al :thumbup: a reminder of why I love this forum, and that good people still exist when you look in the right places ( such as this forum :lol: ). Thanks everyone for helping out too :)
Gazfirestormowner
Post by Gazfirestormowner »
Now u can stop worrying ymv and enjoy your hell beast
Big :thumbup: to al for helping said ymv out
Virt
Post by Virt »
Gazfirestormowner wrote:Now u can stop worrying ymv and enjoy your hell beast
Not until it's unrestricted :wink: Aha. I was enjoying it beforehand, but now I have a legitimate excuse though to try out that top speed run I've been worried about doing until now :? :lol:
So what was the issue then. Why the cutting out? Good to hear that the stopper has been done at long last. Well done Al :clap: I was starting to get paranoid for YMV :lol:
Virt
Post by Virt »
cybercarl wrote:So what was the issue then. Why the cutting out? Good to hear that the stopper has been done at long last. Well done Al :clap: I was starting to get paranoid for YMV :lol:
HE'S BACK EVERYONE.
No idea Carl, it still does it occasionally on the new spark plugs and air filter. I'm guessing it's the TPS so I'll have a look at that sometime when I can be bothered to strip the bike down, will probably be around the same time I fit my new throttle.. So sometime next month
Yep you don't get rid of me that easy.
And it's done it twice since I left work. Each time I stopped at a junction. Did it 3 times this morning. Other than that it hasn't happened.
Is only after heavy braking.
Carb Breathers
Virt
Post by Virt »
Nah, it does it while stationary even if I haven't moved recently. It does do it after heavy braking as well though, I'll check that link out. I'm fed up of cutting out at my favourite roundabout :lol:
When it was doing it constantly on Wednesday it was doing it even if I hadn't moved, it just didn't want to stay turning over for more than 40 seconds. I dunno why, it's lessened down now though
Carb sync and tps set up ? Pop round one day and we can get it done
Virt
Post by Virt »
lloydie wrote:Carb sync and tps set up ? Pop round one day and we can get it done
No idea about carbs but TPS isn't set up, it's on my to-do list. It's a long list, unfortunately :lol: Just give me a date when you're free and I'll see what I can do :thumbup:
And the idle is too low, I was going to raise it up 300rpm but I forgot
Virt
Post by Virt »
It idles at 1300-1400 though? At least when the engine is at normal operating temperature
sunday the 1\12 or the 8th .
get yourself 1/2 meter of vac pipe and an adapter both are cheap sadly i aint got any in stock or a link to some :oops:
