MacV2 wrote:Dialectic Grease is for electrics Sirch... Don't know what you've been reading...
Have a look at the write up on this one...
http://www.ebay.co.uk/itm/Dielectric-Gr ... 588fd87e66
Much the same as on the other ones as well...
Plain silicone grease as in the other link posted is still cheaper...
Mac, I'm not disputing the fact that Dielectric grease is used on electrical contacts. Cheers for the link
As in my original question, I was trying to find out whether I should be using Non-Conductive or Conductive grease for this purpose. It looks like Non-Conductive is in the lead
Gazfirestormowner wrote:My view would be that the Vaseline would keep the contacts dry but won't stop metal to metal contact so would not stop conductivity and it would have to be a hell of a hot day +30 degrees c for Vaseline to melt so shouldn't have a problem in the uk
Gaz, That is more or less my opinion
mattycoops43 wrote:Yup +1
Vaseline or normal grease even. When I take block connectors apart, I fill them with grease before reconnecting. stops the spades inside from corroding, and the mechanical pressure pushes it away from the places it needs to.
Never had a problem.
Matty, I have been using Vaseline on battery terminals for years (bikes, cars & vans included), it was only when researching this subject I found that I shouldn't have been coating the battery posts and leads in Vaseline before fitting them together. Apparently you should clean the battery posts and leads first, fit them together, then coat with Vaseline so that keeps the moisture out. Even so like yourself I've never had a problem using it.
Thanks to all who contributed to this thread
I've decided I'm going to leave the Vaseline on the Storm's ignition contacts as it is for now. I'll keep my eye on how it goes over the next year. If I find it starts playing up like it did before I serviced it, then I know what to do.
