gasket things
chric
gasket things
Post by chric »
so i get a tighter fit at joint on my exhausts what would i order :problem: :think:
Re: gasket things
chric
Re: gasket things
Post by chric »
its more for the gap about 1cm wide or do they slot in and then push on think they would make can unable to fit
Re: gasket things
Where do you want them to fit better ?
chric
Re: gasket things
Post by chric »
ILL GO TAKE A PICTURE :thumbup:
AND HAVE A FAG AND CUPPA WHILE IM AT IT
Re: gasket things
gap about 1cm wide
Are your link pipes for the Firestorm? You haven't got aftermarket sp ones?
chric
Re: gasket things
Post by chric »
no remus grand prix
Re: gasket things
Are there slots cut into the outer pipe? Is there a gasket in the outer pipe? And where is the clamp?
chric
Re: gasket things
Post by chric »
ITS a allen key fittment type and no grove inside iirc ill check again tomorow thanks
Re: gasket things
Not sure you got what I meant - on the end of the pipe are there slots on it like in the pic below - when a clamp is tightened over the slotted section these should seal the outer pipe onto the inner pipe.
chric
Re: gasket things
Post by chric »
NO JUST A ALLEN KEY BIT WHAT TIGHTENS UP PIPE TO PIPE BUT SURE ITS DRAGGING AIR IN WITH IT ASWELL
Re: gasket things
Mmm Odd as without slots the outer pipe can't be tightened down onto the inner pipe If the allen jey bit thing is just wrapped around the outer pipe then it can't do what is says-on-the-box i.e clamp...
darkember
Re: gasket things
Post by darkember »
I know which part he means. Its the joint from the rear header to the collector that should have that self centered clamp on it.
Re: gasket things
You have a slot under the Allen key bolt .
If you want it tighter fitting I'd use a little packing cut out of a coke can then use firegum to seal it all up .
Re: gasket things
lloydie wrote:You have a slot under the Allen key bolt .
Mmmmmm cutting coke then wanting it tighter.....
Never tried the firegum though, for a bit of variety I tried Vick's Vapour Rub but it didn't go well, tbh.
