I need some frames making up. Strength isn't a major issue, but the kit these things hold weighs about 6Kg.
The dimensions are roughly - 500-600mm high by 250mm front to back and 450-500mm wide.
They can be built from square sections of Aluminium or L bar aluminium and either bolted or welded together. I will need the frames drilled and threaded in some places to mount the kit. M3 bolts are the usual spec.
Here's a couple of pics of one a friend made. Something similar should be ideal. I think the materials for each one cost him about £15 plus some for bolts as he bolted his.
If anyone is able to make these, please let me know and let me know how much you will sell them for. I will need 4 initially ASAP, but in the long run could be needing lots of these. Could be a good money earner for someone?
