No that's after dark (dogging without getting caught ) classcybercarl wrote:Lloydie are you doing classes.
Out dogging with the dog then.
First of all a pic from yesterdays hard work
And today I thought I would make a start on a job if put off for toooooooooooo long.......
My exhausts. Needless to say aluminum does not like road salt and grim so the were looking a bit worse for wear. After 3 hours with wet and dry (240 and 320) some autosol and belgom ALU the first exhaust has come up quite well and I am rather happy
also did one of the pillion pegs and both straps for the exhaust.
Looking good.
Have you moved into Lloydies, amazing what a bit of elbow grease can do.
Lloydie & Chris, do you get together to form a spit roast for Virt? Just a thought!!
We're easing him in gently :-).Kev L wrote:Lloydie & Chris, do you get together to form a spit roast for Virt? Just a thought!!![]()
Today I fitted the HRC coolant reserve tank :-)
I gave it a wash after getting back yesterday as the condition was appalling (my garage leaks badly so cleaning it never lasted long
Good lad
gotta keep that Storm looked after
Lloydie, what do you reckon on your new coolant tank?
Jamie
Very nice mate tho you need to get creative when mounting it as it has no brackets .
Fitted HRC sticker to tank. Havn't had it on dyno yet but bike feels quicker !
Jamie
Fortunately not! Rubbish lighting in car park. A brown storm might possibly be even worse than a yellow storm
Hehe that's fortunate then!
I dunno, those yellow Storms
Jamie
Fitted new chain & sprockets and fitted the hugger . Only front brake pads to change and it's MOT ready :-)
Well I got out and made a start on sorting out my rear calliper/pads. Had a bit of an issue with getting one of my chain adjusters undone. One had seized and needed butchering with mole grips and heat to remove
Not sure why that happened as I put plenty of copper slip on last time I had them off. Why are the chain adjusters so sh1t on this bike. They could have at least given us a bigger bolt head instead of a measley 8mm.
Sanded with Dremmel my brake disc as it was showing a slight lip at the edges where contact from worn pads was made.
Cleaned calliper and that is now ready for new pads. Given up for the day now as I was getting shivery cold and my back was starting to go. Yeh could have put more clothes on but that restricts movement and I don't like that. The fun of working outdoors!!
Still got to clean up rusty disc bolts and put the disc back on the wheel. I may as well give the wheel a good clean and re-grease while it's off. Can't be arsed cleaning the sprocket carrier or sprocket. I've also got to investigate the pressure switch and see why that's not working.
Winter is miserable!!!!! I wish we as humans could hibernate like other animals on the planet and give Winter a miss.
