So another swing arm brace install thread.. WHY?...Why not the internet is free
Bike is a 1998 (built Jun 1997) VTR1000F
Donor swing arm is a 94 Honda CBR 900rr
I choose the early year (pre 1998) 900rr because I wanted the brace with the box style front leg. I believe it makes a more stable, better looking swap, then the twin leg version.
The 1998-1999 CBR 900 rr used the twin leg brace.. and I've seen it work out ok, but the sculpted part needed for clearance near the shock, just never looked right to me.. cept one, and that rider boxed in the two legs with sheet aluminum once they were welded.
The 2000 CBR900rr uses a much different swing arm and the brace is not really useable for this mod.
With the donor swingarm in hand, the project started by cutting off the brace
The OEM chain guard tabs were already cut off, so I will just clean up that work and fit a huger chain guard combo.. it does keep chain lube somewhat contained.
As I will be building a under-slung rear brake caliper mount for this MOD, I do not need the 900rr caliper bracket, or the bracket stop from the swing arm.
I will be machining off the OEM caliper bracket stop from the VTR arm as it will no longer be used .
Next step is machining up a caliper bracket strut mount to be welded to the swingarm.
I have ordered materials for the strut, so waiting on those to arrive.
Fitting the brace to the VTR swingarm.. well waiting for that package from the guy in brown....(UPS) on Monday as well.
I'll keep this thread going with updates as I work things out.
