Front Sprocket Inspection
Have never even seen the front sprocket - the rear one wasn't too bad (replaced with new one, 1 tooth higher). As I've only done 300 miles since buying it, thought I'd better have a look. Is it right I have to take the clutch cover off, and do I need to pull the lever in first and tie it to the bars just to get at the front sprocket?
Re: Front Sprocket Inspection
Yup that's the way to do it to save having to rebleed the clutch.
Best to replace chain & sprockets all together. Otherwise its like changing your socks one at a time…
Yeah, that's what I figured - anyone got a good, standard front sprocket for sale?Wicky wrote:Yup that's the way to do it to save having to rebleed the clutch.
Best to replace chain & sprockets all together together. Otherwise its like changing your socks one at a time…
change all three together (chain and both sprockets ) .Mav617 wrote:Yeah, that's what I figured - anyone got a good, standard front sprocket for sale?Wicky wrote:Yup that's the way to do it to save having to rebleed the clutch.
I intend to, already got new chain and rear sprocket.lloydie wrote:change all three together (chain and both sprockets ) .Mav617 wrote:Yeah, that's what I figured - anyone got a good, standard front sprocket for sale?Wicky wrote:Yup that's the way to do it to save having to rebleed the clutch.
I hope you mean Sprocket cover, you don't want to be taking the clutch cover off.Mav617 wrote: Is it right I have to take the clutch cover off
standard tooth http://www.ebay.co.uk/itm/Renthal-16-T- ... 35d23b3e72
-1 for making 1st gear redundant as it will just flip !! http://www.ebay.co.uk/itm/Renthal-15-T- ... 51b95fabfe
Cheers Lloydie, have ordered a standard one. Thanks to Lee also for his kind offer.lloydie wrote:standard tooth http://www.ebay.co.uk/itm/Renthal-16-T- ... 35d23b3e72
Aye, but the sprocket cover means removal of the clutch slave cylinder cover also apparently.popkat wrote:I hope you mean Sprocket cover, you don't want to be taking the clutch cover off.Mav617 wrote: Is it right I have to take the clutch cover off
sh1t! Didn't tie my clutch lever inWicky wrote:Yup that's the way to do it to save having to rebleed the clutch.
You can remove the sprocket cover with the clutch slave still attached. You have to remove either one or two (sorry can't remember) outside bolts on the slave as they also hold the sprocket cover on. Leave the others in on the slave and remove the sprocket cover with slave still attached.Aye, but the sprocket cover means removal of the clutch slave cylinder cover also apparently.
Loosen the front sprocket bolt before removing the rear wheel or cutting the old chain off
Leave this one dun up as it holds the slave to the cover all the others hold the cover to the engine
I left the clutch lever well alone & just cable tied the slave cylinder piston
I drain it tbh as it can do with a change once in a while and it don't take long to bleed it
Oh well done Lloyd I was having a moment there.Leave this one dun up as it holds the slave to the cover all the others hold the cover to the engine
I cable tie the clutch lever in.
