Two years ago my Storm started to lose air from the front tyre. At the time I was using a Puncture Sealant that you squirt inside the tyre then reflate. I put this down to the sealant causing the corrosion, but to be fair I had been using the same make of puncture sealant for many years without any problems.
The rear wheel turned out to be badly corroded as well. This resulted in having to replace both front and rear wheels because they were so badly pitted.
That was around two years ago, now today I find I have the same problem, the rear is losing air again at the wheel rim where the tyre bead sits
I'm I on my own with this one
