It's well loud but it's a big unit poss could squeeze it in under the clocks but you'd have to extend the wires from the left hand switch gear, that's if you wanted to fit it to your Storm... Will be tested before sale.
Would fit cars & vans as well.
£25 posted.
Standard Shock. Came off 'Ole Red when I fitted the Nitron. Mileage then around 21k, bit tatty but worked fine & carried my fat butt around no problem...
£20 posted but most of that will be post due to weight...the shock not mine... SOLD
Side Stand Switch.
As standard removed from 'Ole Red was working last time I put the stand down out side Tonys...
£7.50 posted.
Any one who wants more than one item postage will be adjusted...
