front indicators
macdee
front indicators
Post by macdee »
hi men i'm after some ideas for my front indicators
what would you suggest
thanks
Re: front indicators
macdee wrote:hi men i'm after some ideas for my front indicators
thanks
100's of types to choose from take your pick what ever you like TBH.
I use these...
http://www.jsaccessories.co.uk/accessor ... -shem.html
Long ones on the front short on the back but you will need a new flasher relay as well.
You cant mix front & rear with LED's its both ends or nothing...
Saintsman27
Post by Saintsman27 »
I thought about swapping mine from the standard fitted and whilst digitals
look good and modern and shall I say " Flashy "....... but I decided to stop with the originals
I quite like the standard big bold and visible VTR indicators that Honda designed and fitted and
can be easily seen at speed by other road users. :thumbup:
Ckennedy
Post by Ckennedy »
Get some flush fit clear lens ones :thumbup: had them on mine. They looked good
Or you could get some little flags that pop out and up when you push the button. A bit like the old Morris travellers. :biggrin
cliveyandrews
Post by cliveyandrews »
I have mixed incandescent (OEM) indicators front & LED rear with no issues (solid state relay though)
Audi, Vide, Tace
Mav617
Post by Mav617 »
Nickcv
Post by Nickcv »
thanks
I use these...
I have these along with an electronic flash relay which makes sure that the indicators blink at the correct rate.
