Essex workshop day - Colchester - Sat 26th April 2014
Re: Essex workshop day - Colchester - Sat 26th April 2014
If you get a replay we can wire it up to your side light and use that as the switch rather than having an independent switch in series, then it will switch off with the ignition or switched off whilst riding.
Sorry old bean thought they were brake lineslumpyv wrote:done the front one last year , that works ok so no worries
"It may be yellow but it ain't no chicken"
good spot carl, I did know that, that pic is just lifted off bing images not the actual line wot is hiding in my garagelloydie wrote:mines cablecybercarl wrote:Err you do realise our clutches are hydraulic not cable. Unless of course your thinking of converting.![]()
cheers ladsbazza696 wrote:If you get a replay we can wire it up to your side light and use that as the switch rather than having an independent switch in series, then it will switch off with the ignition or switched off whilst riding.
I like the sidelight approach, so what would I need, a relay, some wiring and a 12v marine grade charger, anyone got some links for these items, also how/where do I attach it to the front/dash area of the bike?
Hiya, I'm new here and in fact this is only my second post, so I'm being a bit cheeky really, but I'd like to come along to meet some forum members and also, of facilities and tools permit, strip and grease the rear suspension linkage on my newly acquired storm. I can bring a 240v rattle gun and some impact sockets if it will be of any use, together with a leak down tester if you have a compressor?
Regards
Neil
Regards
Neil
Insurance: Bennetts CH24823B Exp 21/07/17
Mot Exp: 22/05/2017
Tax Exp: TBA
Mot Exp: 22/05/2017
Tax Exp: TBA
Hi Neil. You shouldn't need to bother with the rattle gun as I am bringing mine
I can't see it being a problem with you turning up
Sent from my HTC Sensation XE with Beats Audio Z715e using Tapatalk
Good to see so many new members interested. This is what workshop days where designed for.
I think it's Jamie's mum tbh :-)cybercarl wrote:Good to see so many new members interested. This is what workshop days where designed for.![]()
Or Jamie
cybercarl wrote:Or Jamie![]()
Hiya Neil, you are most welcome to the workshop day, are you any good at flipping burgers?Kurt999 wrote:Hiya, I'm new here and in fact this is only my second post, so I'm being a bit cheeky really, but I'd like to come along to meet some forum members and also, of facilities and tools permit, strip and grease the rear suspension linkage on my newly acquired storm. I can bring a 240v rattle gun and some impact sockets if it will be of any use, together with a leak down tester if you have a compressor?
Regards
Neil
Good to see you are planning to take a look at the swingarm linkages, I have a compressor if you need to use it
Jamie
Not the preferable option!cybercarl wrote:Or Jamie![]()
Jamie
I'd go for both
Stop being so picky !
Cool!!! how do I find out where it is though?
I mentioned the compressor in case any one was interested in running a leakdown on their motor. I'll bring the tester anyway.
Cheers people
Cheers people
Mot Exp: 22/05/2017
Tax Exp: TBA
Mot Exp: 22/05/2017
Tax Exp: TBA
