howdy guys ,
just wondered if anyone had an idea what might be wrong with my bike ,
i have an uneven tickover , bike was previously fine now it sounds like it is hunting ,
its not valve clearances ,
i have stick coils fitted ,
bike performs fine , its just a very uneven tick over ?? ive had to raise the idle to stop it cutting out , mechanically im pretty good , but just find this a bit odd and wondered if any storm owners have had this problem ,
ill probably start with plugs , but there fresh enough tbh ,
and if it was the carb idle circuit id expect up to quarter throttle hesitation etc ,
as i said , just wondered if anyone here has come across the same problem
uneven tickover
uneven tickover
its not the dog in the fight its the fight in the dog
- Redthunder
Re: uneven tickover
Carb balancing,
Maybe a poorly performing spark plug
Maybe air leak (include exhaust in this)
- bigtwinthing
Re: uneven tickover
Check all your fuel and air hoses.All clamps etc, probably an air leak. Check the carb rubbers as a small split may cause that too.
Re: uneven tickover
Are you getting popping and banging from the exhaust on the overrun?
- bigtwinthing
Re: uneven tickover
Don't say thats bad Tony mine does that like a bugger!tony.mon wrote:Are you getting popping and banging from the exhaust on the overrun?
- Furrybiker
Re: uneven tickover
Yeah, I thought that was a feature!bigtwinthing wrote:Don't say thats bad Tony mine does that like a bugger!tony.mon wrote:Are you getting popping and banging from the exhaust on the overrun?
Re: uneven tickover
I'm thinking about a vacuum leak....
Re: uneven tickover
thanks for the replies guys im going to have a look , i do have an exhaust leak alright , ill check it out , and shout back , if anyone would like to offer an opinion , feel free , ill try to seal the exhaust and check for inlet leaks , check stability of the stick coils , and fit a set of plugs , throttle position sensor mod already done , probably be a few days before i get it checked out
just to add no noticeable difference on the overrun
Re: uneven tickover
Not even a bit of popping and banging from the exhaust leak? Any intake or exhaust leaks, more so intake will cause an uneven idle. The next thing I would be looking at is the mixture. Do a blip test to to verify things.just to add no noticeable difference on the overrun
