High comp pistons being fitted this weekend
So if anyone wants to pop by and see the process, I'm spending the BH weekend fitting high comp pistons to my engine, starting tomorrow early.
It'll have to be done in three days flat, as I need the bike to get to work on Tuesday.
Car's off being repaired after an idiot didn't notice me and pulled across two lanes.
So I'd best get an early night and get started first thing.
In Sevenoaks, Kent, if you haven't been round before.
Re: High comp pistons being fitted this weekend
hope it all goes well for you
Good luck tony ,shame your not closer to me or I'd of come round
Good luck with the rebuild Tony.
I'd pop round but I'm off the road at the mo...
Don't forget if you have any issues & can't get it done for ready for Tues the offer of a loan bike is still on...
I'm sure I could find one for you to borrow...
Fixed it for youGood luck tony ,shame your not closer to me as I'd come
He could always use the Chinese ScooterI'm sure I could find one for you to borrow...
I'm supposed to be woodstaining a shed down in Guildford. Anyway the only bit I would be interested in seeing is your starting procedure, the first push of the switch and sealing your rings in. What's your running in procedure/technique.
Probably aiming it at the nearest puddle to get all the new bits dirty, to match the rest of his bike...cybercarl wrote:
Good luck with your engine rebuild Tony, don't rush it, I hope all goes well
Oh and pop them in the correct way round this time !!!
and take some pics too
yea take lots of pictures. are you doing the method that doesnt require splitting the cases? STD bore or OS?
im about to put another set of JE's into the new track VTR in a week or 2. i was gonna just put the already higher compression motor into the track VTR but i figured, hey why not just have higher compression motors in both bikes ehh?
LOL was about to add the same commentlloydie wrote:Oh and pop them in the correct way round this time !!!and take some pics too
So how's the first day gone Tony? or are you still working on the rebuild right now
I'm guessing Tony has locked himself in the workshop
Hope Alls going well
All going well.
Stripped, no issues, well, snapped mounting on the coolant overflow bottle, but i have spares...
Bike's having a little lie down to recover, while I go in from underneath.
Byebye, pistons...in you go.
The bin in the background is a parts bin, and that's still allowed, I hope?
And yes, you can just about get to all four on the big end bolts without taking the oil pump off, but's it's a bugger, that last one...it's hard to ensure that it's properly torqued.
Just to make sure I ordered five big end bolts, in case one gets rounded off.
I think next time I'll pull the clutch and oil pump off anyway, but wanted to see if Scobey was right
Fixed it for you.The bin in the background is a sharps bin, and that's still allowed, I hope?
Now go and get a blanket and pillow for your bike. She'll get cold overnight. Say bye to the shinyness on the pistons. You do realise that threads like this really tease me onto wanting some hi comps even more so.
