in dash gpi
in dash gpi
earlier this year I bought a healtech gear position indicator or GPI for short, I've always wanted one, I was fed up of hitting first gear for a slow corner when I wanted second.
I could have just stuck it on the side of the dash like 99% of people.
but seen as I had a spare dash from a salvage bike, I thought i'd give the gpi mounted inside the dash a go.
with the help of carl, we started hacking away to make space for the gpi, the healtech gpi is one of the smallest units on the market but we still had to trim it down here and there, plus lots of cutting into the backing plate behind the rev counter.
by far the hardest part was cutting the rev counter fascia.... :eek2
it's a one hit wonder, well it didn't go perfectly, but it wasn't that bad, the next thing was once it was all mounted back together the cut of the rev counter fascia against the gpi looked a bit rough, so it went in the cupboard for several months as I was a bit unhappy with it and other things were more important.
then I read the thread recently posted about gpi's, so I thought it's time to finish the project. I decided to take a black marker pen to the rev counter fascia, again it's far from perfect, but i'm now happy to use it, in the pictures you'll notice the top cover clear plastic needs a good clean and I need to refit the rev counter needle but other than that it's ready to fit and programme in...... :thumbup:
thanks for your help carl.... :thumbup:
Last edited by agentpineapple on Fri Sep 26, 2014 7:49 pm, edited 3 times in total.
Re: in dash gpi
Mate, I like it very much :D , good on ya both for having a go at summit different! :thumbup:
Re: in dash gpi
looks good fella, don't bother with the rev needle until after your dyno runs :lol: :lol: :lol:
Re: in dash gpi
Looks right smart that :thumbup:
Re: in dash gpi
Oy it was my idea and you helped me. Well... we helped each other with measuring and cutting different bits, but it was my idea. :lol:
Your right the alignment and cutting of the White facia is the hardest part. It don't look too bad for a first attempt. I reckon with a bit more time and all the right tools to hand that would look pukka. All it needs is a frame around it so it looks like the outside of the LCD to the right of it. :thumbup:
We did try cutting some Carbon wrap into a frame around it. But that was just too finicky....especially without a sharp scalpel blade and cutting board to hand.
Re: in dash gpi
calm down calm down mate................ :lol: :lol: :lol:
it was a joint effort, lets leave it at that...... :wink:
at least my bike will now never do more than 16000 miles.......... :wink: :lol: :lol: :lol:
although I won't be fitting it until after the mot.
I've also been looking into buying some tinted film that could be put on the underside of the rev counter, that way when illuminated it will be a different colour.
I was looking at this, what do you think.....http://www.ebay.co.uk/itm/181466236613? ... EBIDX%3AIT
not sure if it'll work, but it might be worth a try
eamonn
Re: in dash gpi
Post by eamonn »
Nice work I want one !!!
Re: in dash gpi
Argh.... you not going to believe this. I have just thrown out some Green and Red transparent sheets I had knocking around for filmaking/lighting. How would you stick it down :think: I'm looking forward to seeing that gear indicator up and running.
Re: in dash gpi
That looks good Marty, well done to the Marx brothers!!! You could always try learning to count to six though, might be easier!!!! :lol:
monkeymatt
Re: in dash gpi
Post by monkeymatt »
Good job :thumbup: looks cool maybe you could find a bit of yellow tint :crazy:
Re: in dash gpi
this dash will probably end up in the blue bike and as such my first choice would be blue film, it should have an adhesive finish on one side so you can stick it to the clock fascia.
and kev we are laurel and hardy not the marx brothers, how very dare you.... :lol:
Re: in dash gpi
If we are laurel and hardy that must make Kev charlie chaplin and Al and Lloyd the marx brothers. :P
Re: in dash gpi
I think al and lloydie are more like hinge and bracket............... :lol: :lol: :lol:
and virt is kevin the teenager, same haircut and everything
Virt
Re: in dash gpi
Post by Virt »
Nope. I'm amazing, describe me in any other way and you can go wombles yourself :lol:
bald_pig
Re: in dash gpi
Post by bald_pig »
Nearly christmas, wait for the quality street ;)
