ssssplutttteringggggg
Flatline
Post by Flatline »
Out for a ride today when the bike started to go on to one cylinder intermittently
Managed to limp home, but now come the investigation
The cylinder seemed to cut in one out when the bike rode over rough surfaces
So, what should I be checking?
Loose connnections seems like a good place to start
Which connnections and where?
Spark plugs and leads
Anything else that should be on the list?
Re: ssssplutttteringggggg
Coil leads and earths is where I'd start
Veturinkuljettaja
Post by Veturinkuljettaja »
Loose negative battery connection gave me similar symptons once.
'99 Firestorm a.k.a.VETURI
Pearl Lively Orange
"Self-Rogered" forks with Racetech linear springs, Yoshimura RS3 SS, DJ Kit, Krieger CCT, SHINDENGEN FH020AA R/R, MRA Racing windcreen, Tapered steering head bearings, gl_s_r brass nuts :)
Flatline
Post by Flatline »
I now know its has no spark at the front cylinder
Flatline wrote:I now know its has no spark at the front cylinder
Front coil, swap them front to rear and see if the rear pot goes off! I assume you've tried a new plug?
Also swap plugs front to back, but not at the same time and the coil. Probably easier to do the plug first.
Flatline
Post by Flatline »
Sorted
Faffed about with coiles and plug leads
All working now
Thanks for your input
bigtwinthing
Post by bigtwinthing »
make sure the holes are clear in the front head drilling , it fills up with water
