44T Rear Sprocket?
Re: 44T Rear Sprocket?
bigtwinthing wrote:or buy a Tuono, more power as stock. USD forks, faster etc, oops sorry this is a VTR forum. :lol:
Wash your mouth out :lol: , although Ck does have a pic of me trying a tuono for size at the NEC 8O
only ever had standard gearing and -1f +1r, and the latter was great low down, but as tony said at motorway speeds it was tiresome, always felt like the bike needed a 7th gear, it also effects fuel consumption as the bike cruises at a higher rev. not to mention the speedo needs recalibrating, not that I did that bit.
Last edited by agentpineapple on Wed Jan 07, 2015 6:29 pm, edited 1 time in total.
agentpineapple wrote:only ever had standard gearing and -1f +1r, and the latter was great low down, but as tony said at motorway speeds I was tiresome, always felt like the bike needed a 7th gear, it also effects fuel consumption as the bike cruises at a higher rev. not to mention the speedo needs recalibrating, not that I did that bit.
Your always tiresome Marty & there I haven't fixed it for you at all... :wink:
lumpyv
Post by lumpyv »
tony.mon wrote:it's not so much what you lose as how many revs you are doing when cruising on motorways in top.
Lowering the gearing means losing that long-legged feeling of travelling at fats motorway speeds at less than half the revs available.
OIC , thank you .
I tried a +2 on the rear sprocket, it really livens up 2nd gear which is great fun and does feel like an increase in bhp, but I found I was a slower rider as a result of loosing that long broad delivery with the standard gearing. I was on/off the throttle more and slower as a result.
Standard gearing is spot on imo, it's just the Storm could do with an extra bit of fizz in the motor to make the front wheel a little lighter :D
lumpyv wrote:Yes and Yeesss! Go for +2 on the rear. My favourite mod on the Storm, it feels like an extra 20bhp and only for £20 :Woohoo1:
how much does this knock of the top end ? ?
Lumpyv,
According to my calculations that I had written down from some years ago, you lose 8mph from the top speed by lowering the gearing with two more teeth on the rear sprocket. That means 169mph top speed down to 161mph. IIRC the increase in rev's is 500rpm higher with this mod,
