Fecked up my linkage roller bearing fitment :thumbdown:
http://www.vtr1000.org/phpBB3/viewtopic.php?f=7&t=35837
TravisZack wrote:My friend's track bike is on a daytime MOT, the only thing he's added is a strip of red LED's for a brake light, purely for safety on the road. Might be worth considering so no one runs in to you and you can always disconnect it at the track.
I will do after the mot :thumbup:
kev64
Post by kev64 »
Got RH fairing back from sprayers, middle part nearly done, ready for assembly and fit Saturday
Fitted mixture screws
Coolant change
Clear coated frame (and f**ked it up so start again tomorrow)
Clear coat exhaust headers
:confused
gabi81
Post by gabi81 »
Changed all bolts and nuts for titanium ones :beer:
Fitted adjustable levers
New grips
6mm spacer at back
Gave it a service and started to fit the belly pay for the mori headers .
I want the pan as high up as it will go to give me as much ground clearance as possible for them right handers
dumpertruck
Post by dumpertruck »
Fitted my speedo pickup. More sanding on the belly pan :(
kev64
Post by kev64 »
:confused
satin vht, over the paint, bit of extra protection against stone chips
Fitted seat pad / belly pan / number plate .
Still wAinting for the tank :-(
Blurry pic as it just started snowing again and I wanted in .
Ckennedy
Post by Ckennedy »
That belly pan looks a fair bit higher Lloyd. Did it go up much? Does look nice in black.
Mav617
Post by Mav617 »
Ground the pins out of the footrests, so I can fit some shiny new ones.
Cut a slot in frozen screw on the chain guard and got that out.
Cut down the rear brake push rod to get the right pedal height - a good day all round with the Dremel :) :)
boring oily stuff.. oil, filter,air filter..
i want out on my bike NOW ffs.. bored with this sh1t weather
Had a big sort out in the garage and finally started to build the tuned engine .
Pistons in crank in , gearbox in .
Need to pop into honda to change the seal they gave me as it's not the correct one for the clutch push rod ,
Them Pistons c clips are a right fecker to locate in and thankfully ck helped fitting them ( well he fitted them for me :thumbup: ) .
I hope to finish it for next weekend and order the shims .
And you never know I might have it fitted for the devon run [THUMBS UP SIGN]
Good work Lloydie :thumbup:
Your putting my build to shame......................hang on everyone is :lol: :lol: :lol:
you'll be able to investigate the devon shrubbery at greater speed....... :thumbup:
