l/h switch gear.
Moderator: VTRDark
Diabolus
l/h switch gear.
Post by Diabolus »
must be off a low milage or newer vtr, mine is wombles and as its a common fault i gather that any vtr replacement will eventualy fail too.
http://lincsrideouts.co.uk
carmanbikes
Re: l/h switch gear.
Post by carmanbikes »
Diabolus wrote:must be off a low milage or newer vtr, mine is fooked and as its a common fault i gather that any vtr replacement will eventualy fail too.
What is it that goes wrong with the l/h switch
Diabolus
Post by Diabolus »
indicators wombles up, sprayed cleaner in ect...... looks like I Will damage it if completely strip it, I would prefer a replacement and then take the faulty one apart.
Overuse I think and the contacts wear eventually. It don't help when people spray Wd40 etc in them as quick fix. This basically builds up and congeals and acts as somewhere for bits of dirt and grime to stick to, which then adds to the wear and tear. It's best to strip them down and give them a proper clean and use a dielectric grease which is designed for the purpose. Vaseline would do, but don't pack it out with grease, only use what is necessary.
Diabolus
Post by Diabolus »
http://www.guagerepairs.com/
just contacted this guy for a price, Im in middle of working on a bandit, I can't be arsed with it.
Diabolus
Post by Diabolus »
I can be arsed now. he wants between £40-£110!
gabi81
Post by gabi81 »
i have one u can have
its missing high beam flash button but its working order free if you cover postage
Diabolus
Post by Diabolus »
all sorted now.
