Love that pic of the brake line
It's starting to come together nicely
Did you key it first if so should be goodlumpyv wrote:I painted my new 2nd hand oil lines with high temperature matt black spray paint.
I wonder if it will be up to the job or just blister off ? ?
+1looking great travis....
You beat me too it. Yep as long as they had a good rub down and nice and smooth before applying the paint all will be good.Did you key it first if so should be good
It's a gen 2 engine that we're taking the heads off and fitting them to his gen1 engine (10-15bhp increase) along with bigger throttle bodies and modded exhaust .AMCQ46 wrote:lloydie,
why do you have CK's engine in your garage? are you checking to see if it will go in a VTR frame?
There's pills for thatmental mods to the frame
Cam profile and porting is different and larger valves ,cybercarl wrote:There's pills for thatmental mods to the frame![]()
That's a big increase. I take it that cams are more extreme in the gen 2 then?
I'm on a later model so already got black rads but they are a little flakey at the front. I'm going to scrub them back and respray with some high temp spray paint, unless I'd be particularly better off using this Eastwood spray?agentpineapple wrote:travis....
have you considered painting your oil cooler and radiators black, frosts/eastwood make a excellent satin black paint specially for radiators, it's a touch expensive but a great product.
http://www.ebay.co.uk/itm/Eastwood-Radi ... 589145c136
Well I guess you need to balance things out a bit to make it a fair competition.think he only doing it so he still has a advantage on the straights on the track as my engine build has him shaking in his little boots !!!
I know there is a common oversize kit which gets Apes to 1060cc, wasn't familiar with 1080 unless it's a one-off kit. Anyhow, having done some reading on said 1060 kits, they really wake up the engine (with gains well above the expected 6% gain from displacement, the added intake velocity really helping torque production) .... wish someone made something similar for the VTR........lloydie wrote:Cam profile and porting is different and larger valves ,cybercarl wrote:There's pills for thatmental mods to the frame![]()
The gen one has round ex port and the gen 2 has oval where it meets the header pipe so that's why you need to mod the exhaust too .
I'm trying to talk ck into doing the big bore too as that will take it to 1080cc and with the other mods get it near 150bhp with dialled in cams !! (Just want ck to sh1t himself when he rides it )![]()
We need to get on the Dyno first to get a base run for comparison .
I think he only doing it so he still has a advantage on the straights on the track as my engine build has him shaking in his little boots !!!
big bore is not easy but possible, http://www.thiel-motoren.de/, or you can find somebody local who is able to do wet liners. I am fine with 1000cc :-)mik_str wrote:I know there is a common oversize kit which gets Apes to 1060cc, wasn't familiar with 1080 unless it's a one-off kit. Anyhow, having done some reading on said 1060 kits, they really wake up the engine (with gains well above the expected 6% gain from displacement, the added intake velocity really helping torque production) .... wish someone made something similar for the VTR........
Sorry yes 1060 kit my bad :-(mik_str wrote:I know there is a common oversize kit which gets Apes to 1060cc, wasn't familiar with 1080 unless it's a one-off kit. Anyhow, having done some reading on said 1060 kits, they really wake up the engine (with gains well above the expected 6% gain from displacement, the added intake velocity really helping torque production) .... wish someone made something similar for the VTR........lloydie wrote:Cam profile and porting is different and larger valves ,cybercarl wrote:There's pills for that![]()
