Possible new owner
popkat
Re: Possible new owner
Post by popkat »
VFR gear drive cams nice and reliable, if you did have a tensioner fail on the CBR it'll let you know with a rattle, then it's easy replacement, basically just whip it out and pop a new one on. Unfortunately the firestorm is a bit more complicated, first sign of a rattle can often be too late and result in valve or cylinder head damage. There's a guide on here (which you may have already seen) which will walk you through it all (stopper mod or fitting manual tensioners) follow to the letter and you'll have no troubles. In the case of these bikes Prevention is definitely better than cure.
popkat
Post by popkat »
artee wrote:
agentpineapple wrote:
artee wrote: Any one have a piccie of a standard shock?
Roger
click on this ebay link fella.....http://www.ebay.ie/itm/Honda-VTR1000-Fi ... 51c0c5eba1
Thanks.
I take it the adjuster at the bottom of the shock is a damping setter.
Roger
Yes the one in picture number 5, should be accessed from the right hand side of the bike.
Flatline
Post by Flatline »
Welcome aboard buddy
welcome along to the site site.. :thumbup:
artee
Post by artee »
Getting excited.
Pick up the bike tomorrow (Saturday)
artee wrote:Getting excited.
No sleeping tonight then :thumbup: good luck tomorrow and have a good ride back
artee
Post by artee »
Its a trailer job.
The bike has been stored for 4 years.
Ive seen it and heard it run :D
Roger
Never mind ,give it a good going over when you get there and check for rust in the tank also if you get it sort the ccts asap
BrianC
Post by BrianC »
Hello roger
And welcome. At that price it's worth a punt- I' m massively excited with my w reg storm I got last week.
It cost me £1000 and it's massive value. - just need to give it a full service and fluids change then there we go !!!!!
This forum is amazing and was a great inspiration to me to get a storm - and I'm in leyland if you ever fancy a chat
Brian
Did you get it roger ?
lloydie wrote:Did you get it roger ?
He's still out in the man cave admiring his new bike :thumbup:
artee
Post by artee »
Got it.
Also bought the battery for it.
I'll get it running after cleaning the starter conections as the starter seemed to struggle.
Will take some piccies :D :D :D
Roger
artee
Post by artee »
Unfortunately its snowing here in Rochdale.
I dont have a garage to work in, the bike is in a large shed along with my Vfr.
Typical British weather.
Roger
artee
Post by artee »
As promised,
Piccies
A bit scabby on the subframe
