I used a new bolt for the centre & used the dimensions given on the first page of the thread as a guide
The gauntlet has been thrown
I was hoping to beat Carl's light one but it was a bit of a fluke to be honest, as once it (the flywheel) has been removed it would of required an new bolt to centre & I ain't got one.lloydie wrote:When you fit that it will spin up super fast !!!
I am out of VTR ones now....lloydie wrote:Drill one to find out
No, leave the rivets well alonefabiostar wrote:rite just so i got this in my head one last time..... do you strip the weight of the back or the basket and cut them down as separates and bolt them back together again?
I asked similar questions & was warned not tofabiostar wrote:without using the end of an old crank have you or anybody turned down a flywheel holding it any other way? can it be held say using the chuck jews on the inside as in the magnets?
Same thing here, basket is always out of true.. I skim all of them now, or take down a bit depending on what is wanted for a final weight.gl_s_r wrote:Yes the basket was out but i skimmed that up as part of the job anyway to make sure it wasn't a problem when removing any balancing holes..
That is how I cut mine...... using a "Buch Chuck" then adj for "0" run out and you are good to go.Varastorm wrote:I asked similar questions & was warned not tofabiostar wrote:without using the end of an old crank have you or anybody turned down a flywheel holding it any other way? can it be held say using the chuck jews on the inside as in the magnets?![]()
If you were to hold it with the basket, you would have to use a 4 jaw chuck & DTI the weight section to "0" run out then cut it![]()
It might be okay? It would have to be your call though.
